Higher Compression Ratios= More HP?
Old Jan 12, 2006 | 09:07 PM
bobmic93's Avatar
bobmic93
Default Higher Compression Ratios= More HP?
My 93 vette is in for heads and cam and the installer uses Fellpro 1074 head gaskets. He is telling me to tell my head porter to shave down the deck enough to gain higher compression. My porter is shaving the deck down butt doesnt want to take to much off incase I ever decide to go with a 383 set up. My porter recommends using Cometic MLS gaskets around $100 pair. With the Fellpro I will see 10.8 to 1 compared to Cometic MLS will give me 11.3 to 1. What do you guys think? Any HP gains by going with the Cometic? How does higher compression change the characteristics of the car?
Old Jan 12, 2006 | 09:28 PM
Nathan Plemons's Avatar
Nathan Plemons
The LT1 will allow you to run a higher compression ratio without trouble due to the reverse flow cooling. However this will make it that much more important that you always run premium fuel. If everything else is held constant an increase in the compression ratio will give you an increase in power but it will not be as big an increase as you might expect.
We had some information about this in my Thermodynamics class last semester, so I started playing with the numbers and I found that the power increase found by raising the comrpession was probably not even worth the effort.
Old Jan 12, 2006 | 09:30 PM
jfb's Avatar
jfb
Increasing compression to increase hp also forces you to use high octane fuel so you don't have knock. You cannot just increase compression. I don't know what you can expect from 10.8 to 11.3, but I doubt its worth it.
Old Jan 12, 2006 | 09:33 PM
bobmic93's Avatar
bobmic93
Can I expect quicker throttle response? I only put Mobile 93 in it anyways. I would be going from stock 10.5 to 1 to 11.3 to1 Doesnt the Zr1 run 11 to 1?
Old Jan 12, 2006 | 09:42 PM
rick lambert's Avatar
rick lambert
Hmmmmmmmm! we used to always shoot for higher compression ratios-
but the only thing I can say-is mess with octane ratings-actually the lower the better-if you expierience higher knock counts-try a higher octane rating. In the "old days" we did everything we could to increase
the compression ratio. Maybe your mechanic came from the same school of thought! BTW-anyone going for the highest performance you can get from a SBC goes- first with heads-then with carb-then with cam-then with exhaust!
Old Jan 12, 2006 | 10:21 PM
500hp's Avatar
500hp
Default Do It!
Relatively speaking a 350's 4 inch piston/bore is not that big, which gives it decent octane tolerance. Increasing compression generally translates into more torque, which tends to show up as more efficient fuel usage as engine speed increases. Done correctly, this will create a stronger, useable power curve somewhere in the lower midrange on up to peak power. As to a measureable difference, anything less than a half of a point (0.5) is hard to quantify. However, a definite half of a point, or more, is worth adding if it is not going to cause trouble in a specific engine combination. In your case, since you run 'good' gas and were going to use quality head gaskets either way, I would do it. Don't forget to run a 160 thermostat and get your fans programmed to suit your type of driving.
Old Jan 12, 2006 | 10:31 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
I'm running precisely 11.3 and like you, I always run 93 octane. It's been a great combination. If all it takes is a gasket, why not? Even if you build a 383 later, this should not be a problem. I'm building something similar to a 383 right now with a zero deck height. Obviously, piston selection enters into this. Quench will be snug by design.
Old Jan 12, 2006 | 10:41 PM
Ramanstud's Avatar
Ramanstud
Don't quote me on it - but I vaguely remember something like a 3% power increase for every 1 point in CR (or something similar).
It IS benificial to increase the CR of a combination, but the dynamic CR is a more accurate indicator of how much CR you can run for a given setup and cam. Afterall, the cam duration is what makes or breaks a setup with reference to CR and detonation tolerance. There are some easy calculators out there (and do a search in C4 Tech, I know I've posted on it in the past).
So for the price of a headgasket and all other things remaining equal... I would do it.
Old Jan 12, 2006 | 10:47 PM
bobmic93's Avatar
bobmic93
If this helps matters any were looking at 224/230 with 112 lobe from comp cam
Old Jan 13, 2006 | 01:24 AM
rick lambert
Forget the 160 thermo-mess with the octane rating and don't worry about the CR-do as your mech.said and don't worry-just enjoy.
Old Jan 13, 2006 | 01:54 AM
silver84's Avatar
silver84
at part throttle, the gain in output
[really efficiency] is three percent, for one 'point'
of compression, ie, going from nine to ten in CR,
and assuming best spark timing, in both cases.
at full throtte, the issue is more difficult,
as most fuels are 'knock-limited'.
Changing from 87 to 93 octane, adjusting both
CR and timing for best in both cases,
I would expect 4 percent gain in power,
some of that being better cylinder evacuation
of exhaust.
IMO, reported gains of more than that,
result from not trying hard enough,
with the starting 'low CR' condition.
Old Jan 13, 2006 | 02:06 AM
Morley's Avatar
Morley
If you get your heads milled chances are you'll also need to get your intake manifold milled the same amount too. If it isn't milled you'll end up with an intake that will no longer seal properly.
Old Jan 13, 2006 | 04:25 AM
No Go's Avatar
No Go
Default Do it as well!
Increase in compression is tried and true way to gain power...how much totally depends on situation.
Until you exceed the 'limit' there are no negatives...if you drive a Corvette one pretty much assumes you run the best octane fuel otherwise why would you be modifying your car...
Another option is set of Impala head gaskets...they are thinner than OEM LT1/LT4 gaskets and cost less than the Cometics. Many have run those on the LT1 with the resultant 11.3 or so number.
I run 11.9 on 92 octane...I also have a somewhat large camshaft, but look at the LT4...raised CR from LT1's 10.5 to 10.8...it just makes sense.
By the way, the 383 issue is one that could impact you on the next build if you deck it too much. The LT1 chambers are already on the small side and then you add a longer stroke...you almost have to switch to dished piston to keep a lower number. My example...54.6 cc chambers, SRP flat top (5cc reliefs) and 3.75 stroke...Fel Pro gasket...11.9. And that wasn't even a zero decked block!
Old Jan 13, 2006 | 05:24 AM
REDC4CORVETTE's Avatar
REDC4CORVETTE
The newer blocks are for smog reasons(higher deck).
I would rather cut the block ,you won't have as many problems in the future.But you could alway's port the combustion chamber to lower compression later.
Old Jan 13, 2006 | 05:40 AM
93 ragtop's Avatar
93 ragtop
Im running the impalla gaskets. They are .020 thinner then the corvette gaskets.
Old Jan 13, 2006 | 08:55 AM
Fuzzy Dice's Avatar
Fuzzy Dice
Cruise-In IV Veteran
I've discussed this with a couple of pretty good engine builders who specialize in Corvettes...they both asked right off how many miles I had on my motor...apparently the higher the miles there is a concern for the motor when raising the CR...
I have 113,000 miles on mine and am looking into H/C as well...just passing along info...good luck
Old Jan 13, 2006 | 09:11 AM
rick lambert
Of course the internals-rings, bearings condition are always a concern when modifying-their probably focusing more on the rings than bearings,
I don't think I'd be to concerned-unless you're already burning oil-and if that's the case-I'd go in with new rings and bearings.
To Higher Compression Ratios= More HP?
Old Jan 13, 2006 | 09:36 AM
kpforce1's Avatar
kpforce1
I hope your builder is ensureing your quench distance is ~.040-.042... especially if you are running a higher compression. I have a cam similar (Cranes version) and a static compression of around 11:1... my dynamic compression ratio was around 8.08:1 wich is well within the streetable area... you just don't want to go past 8.3 on the DCR unless you pay real close attention to everything.
Old Jan 13, 2006 | 02:39 PM
JAKE's Avatar
JAKE
This CR issue comes up from time to time, yes, 1 point in CR translates in to between 3 % and 4% power difference.
The wrinkle is that percentage isn't across the board. What I mean by that is from 11:1 to 10:1 there will be a certain percentage decrease, but from 9:1 to 8:1 a slightly different percentage decrease results.
I have an article that shows the dyno results on changing CR in 1 point increments starting at 11:1 and going down to 8:1. Shows how power is effected.
I posted it on this Forum some time back and will again if you REALLY want to know the results. The tests were done on a NON Chevy (SB Chrysler I believe) engine, but the results can be extrapolated.
Let me know.
Jake
Old Jan 13, 2006 | 02:51 PM
Nathan Plemons
The thermodynamics book shows graphs and such that illustrate the point. It starts as a very sharp angle and then tapers off as compression ratio continues to increase so it is in no way linear. For very short jumps you MIGHT make a fair approximation.
It's kinda like the drivetrain loss expressed as a percentage, it's something that is greatly misunderstood.
