Rear Suspension Moving During Acceleration
Old Jan 13, 2006 | 09:36 PM
93Ruby's Avatar
93Ruby
Default Rear Suspension Moving During Acceleration
Hi All,
Need some help troubleshooting a problem with the rear(I think) suspension. During acceleration I can feel the rear of the car sway over to the right(towards the passenger side). I have lifted the car and did a shake down on the wheels and suspension components, and have not seen anything obviously wrong. Any suggestions on what might be the problem or what I components I should be checking?
Old Jan 13, 2006 | 09:39 PM
Pete K's Avatar
Pete K
A small amount of movement in the center of the rear tie rod assembly can cause what you describe. If it were my car, I would check this area again.
Old Jan 13, 2006 | 09:44 PM
Frizlefrak's Avatar
Frizlefrak
Take a good hard look at all of your rear bushings as well. Trailing arm, differential carrier, strut rod, sway bar, etc. You'd be amazed at how much movement a rotten, worn bushing allows.
Old Jan 13, 2006 | 10:51 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Have the rear toe checked.
To Rear Suspension Moving During Acceleration
