Looking at my 84 electrical shop manual for my 84 the "yellow" wire supplies power when the key is in the accessory or run position. I'm sure I connect the radio antenna wire to this wire, correct?
The antenna relay is engerized when the key is turned to ACC or run and the radio is turned on.
Brimis, I have a Helms at my shop. I'm running out for Lunch right now. If no one else responds I'll post the details according to the wiring diagrams later.
I'm going pink only because its my favorite color!
The yellow wire should hook to the power wire giong into your radio as that the radio only plays when the key is on or in ACC. the antenna coming out of your radio should be hooked to the pink antenna feed wire that energises your antenna relay.
Hope this helps
Jerris
Hope this helps
Jerris
