Normal Fuel Pressure Readings
Need some help troubleshooting a hard start problem. My 93 has an intermittent starting problem--some times it starts right up and other times I have to press the accelerator a little to get it started. This problem occurs anytime, hot or cold. I just checked the fuel pressure reading a few minutes ago and was wondering if it is normal. The pressure cold, before turning key, was 0 psi and after turning the key on without starting, the pressure was 39 psi. The reading running at idle is 39psi with vacuum connected to the fuel pressure regulator and 48psi disconnected. After turning the engine off the pressure was about 39psi and I only watched it for a few minutes before disconnecting and it held at 39 psi. Are these normal readings or do these readings indicate a problem? If these are normal what should be my next step in troubleshooting the problem. Thanks in advance for the help
RACE ON!!!
