L98 HP Class (102)
I'm interested in the 102 class. (This is still a beginner's class where the motor still retains a lot of the stock components). I'm curious what changes are worthless and which ones can provide a good bang for the buck. (Often HP gains translate into mileage gains. In my case, both aspects are worth discussing.)
1) Exhaust. If the precat/maincat configuration is replaced with high-flow (500+cfm) mini cats and the "Y" connections are replaced with true dual exhaust, what kind of improvement would be acheived? (Assume the use of free-flow mufflers). Can increasing the diameter of the pipe from the headers to the back of the car help also? (Assumes use of factory headers). What size is connector is on the factory header (outlet)?
2) Intake. If the stock manifold is retained, can the addition of a "performance" mass air flow sensor provide any improvement? This can include discussion of changes to the air box housing the air filter.
3) Chips. Noticed recent posts about custom tuning chips. Hypertech are pre-programmed aftermarker upgrades. Do they really help? Is the new guy recently referenced a better source for pre-programmed chips -- if you can't go to him and put your car on a machine? Would custom service (programming) be available in a metro area (like Kansas City)? Can the original chip be reprogrammed?
It is my feeling that the Corvette motor is partially designed to resemble a "racing motor". When you look at the manifolds, you see something more similar to a race car than a family car. And, replacing these items begins (what I consider) advanced modifications. Though these are modifications I could perform myself, I hate replacing relatively good H.P. parts.
That means this is still a beginner's course for those who want/wonder what improvements can be realized by getting more air into and out of the factory motor.
Thanks in advance to any "instructor" who chimes in!
Gregg
P.S. I would have included discussion of thermostat temps, but I've read enough about that (in here) lately. And, the pro's/con's don't seem to point to a clear winner.
don't waste your money on the hypertech chip manure, because that's all they are.
when you have done some serious mods, then give alvin a call so that he can burn you a custom chip, alvin is at pcm for less, maybe he'll jump in later and give you some advice.
I think you are on the right track as far as your next mods, keep concentrating on improving the amount of airflow going to the engine.. I would definately get a k and n filter and clean up the maff for improved performance. a good perfomance tune up wouldn't hurt either.
getting true duals and full lenght headers for your car will give you alot of power for the money, but since you mentioned the minicats, i asume you want to stay smog legal, so full lenght headers are out of the question. so yes, get some high flow pre-cats and main cat and have your stock headers ported out. this won't give you as much power as the first configuration but it will give you a noticible difference.
if you do all these mods you're going to require a little more fuel, so an adustable fuel pressure regulator will help you a lot. add little more pressure.
tpis sells a kit that has alot of good parts in it, i think it's called a fast pack, it will have everything needed to vastly improve how much air your motor will take in.
ps i'm no instructor, just a guy who likes to go fast and burn rubber in his vet, i do all my own work.
I would go with the 185 thermostat if you are in a hot summer climate.
I was contemplating the hypertech chip too, but others have said it is not worth what you pay for it. If you can find someone to burn you a custom chip, would be money better spent.
Good Luck
Rock On
if you do all these mods you're going to require a little more fuel, so an adustable fuel pressure regulator will help you a lot. add little more pressure...
2) I've recently read (in here) that K/N filters clog up quickly -- bringing them down to lower performance levels.
3) What do you mean clean up the maff? (clean the wire)?
4) I wasn't planning on getting precats. Do I need them for sniffers?
5) Where do they do "performance tunes"?
6) Would I really need more gas pressure?
7) What about exhaust pipe diameter?
8) Asking for help from "instructors" just meant those with the "know-how"!
gp
A lower temp stat and programming the fan to come on at a lower temp are BOTH required to obtain the optimum results. Just doing one or the other won't cut it.
In my case, the factory install oil on the K&N filter migrated onto my MAF wires, coating them and throwing off the ECM'S calibration. I don't recommend them for MAF equipped cars.
Probably means removing the heat sinks and screens to eliminate the restriction they cause to airflow into the engine.
Probably won't pass the visual exam without them.
No sure what you're asking here. Performance tunes generally refer to having the computer's PROM re-programmed.
There's no set rule on fuel pressure. The "right" fuel pressure depends on the engie variables. Some engines need more, some less and some are fine at the factory setting. It's pretty much a trial and error thing which can be done at the track by monitoring the MPH through the traps or on a chassis/engine dyno.
There are different schools of thought on this. They tend to fall into two catagories: either 1-5/8" or 1-3/4" OD headers. 1-5/8" headers work best with engines in the 350, 383 range. Once you cross 400 CID, 1-3/4" tend to get the nod.
Debatable on both counts. LOL
gp
Hope this helps.
Jake
Hypertech chip (Thermomaster)-Turns my fan on earlier, no performance improvement
-Intake portwork (moderate throughout)from base to TB- +1.5 mph in 1/4 mile..
-Adjustable MAF,dont bother.
-K&N gains debatable, too much filter oil can screw up your MAF.
-Exhaust-Went to 2.5"front and rear "Y"s, 3" main, flos-Best improvement of anything Ive done so far. No longtubes, cant help ya there.
-All the cheap/free mods by themselves that are no good by themselves add up if you do enough of them and may enhance gains as internal mods/ci increase.
JMO, no documented proof though.
Pipe size should be a minimum of 2.5" near the engine and ideally would decrease along the exhaust. The aftermarket headers you may use probably have something like a 3" outlet (2.25" stock), which you could pair with a 2.5"-2.75" pipe after the cats and going into your mufflers. Pick those based on sound alone. You do NOT want pipe size to increase as it travels rear, that will allow the gases to slow down and you want that port velocity to stay higher.
"performance" MAF, junk. Just cut the screens out of stocker.
Generic chips are worthless, only a custom tune should be done. I wouldnt do that until I was either completely done with my mods or I had changed the cam.
There's no excuse to go bigger than dual 2.5" with your rpms and displacement.
I really wasn't talking about changing out the headers, but I appreciate the thoughts in that regard. When I asked about pipe diameter, I meant exhaust pipe diameter (where I'd use factory headers, one cat per dual pipe, and one glass pack per pipe). I was told factory L98's had 2.5" pipe up front and 2.25" pipe after the cat. Interesting that Vader states exhaust SHOULD get smaller!
My personal thought is that the "Y' pipe through the main cat has to be a major restriction. If two 2.5" pipes are "Y'd" into a 3" pipe, 10 sq inches (of cross section) are being pushed through 7". That's one of the main reasons for my consideration of duals.
We don't have inspections (visual or sniffing) yet in Kansas, but I'd like to drive a reasonably environmental-friendly car. I figured two new high-flow cats would do a better job than the 17 yr-old original setup on my car (with 52K miles). Who thinks this wouldn't be a win/win alteration?
I'm also interested in plumbing side pipes (though the "fake" covers). That means I need to control emissions AND sound by mid car (where I'd turn the pipes outward to exit in front of the rear wheels. The alternative would be to put glass packs behind the covers which would require a 180-degree bend to accomplish. (I'll provide more explanation if required). Anyway, I'm guessing this is about the worst thing I could do. (I learned that bends create restriction when I ran exhaust pipe for my down-draft stove).
So, I have the opportunity to redo (improve) the exhuast -- making it cleaner and less restrictive during my quest to gain side pipes. This also led me to thoughts about improving the intake side.
Ultimately, I've heard you can't improve much without doing a lot, but some recent reading have led me to believe that some production considerations keep the STOCK motor from being all that it can be. I'm interested in learning more about those options before considering the installation of bigger headers/intake.
gp
P.S. I gathered that a "performance tune" would involve hooking up a computer to reprogram the computer. Are places that do this readily available in most metropolitan areas? Would this be beneficial to look into with the (minor) types of mods I'm considering?
Sure, if you've moved to some really high flowing heads, longer duration cam, SR or Mini-Ram, etc., exhaust mods make a bigger difference, but unless you've gone that route, I think exhaust mods should be lower on the priority list than a lot of other mods.
I've read Tech articles where back to back testing was done, well over $1,000 was spent on some "high tech" exhaust system with full length headers and those 'cool' FlowMaster mufflers and the engine only picked up 12 or so HP. Now, I said "only" because to spend over a grand for 12 HP isn't a lot of bang for the buck to my way of thinking
If you're looking to pickup 30 HP or more from just exhaust mods - like many ads use to promise - your stock exhaust would have to be extremely restrictive for the engine it's bolted to. Ours aren't really all that bad, relatively speaking.
Just the way I feel about it.
Jake
btw Gregg, 2.25 + 2.25 = 3"
The torque is what I feel and I noticed a nice gain in torque which is where the TPI shines. I don't have actual numbers as I'm no drag racer but I felt it and that's what matters to me. Increase the torque and you are going to increase your fun!
I think that if you are looking at maybe one or two mods probably the best bang for the buck is to put NO2 on the car, other things to look at would be a gear (depending on what is in the car) and some intake work.
Set some type of goal in performance for yourself for a couple of reasons, A) after you start looking at this stuff setting a budget might be a good idea (unfortunately, real parts are not cheap for these cars), so you get things that really work and don't end up buying things that have no or very little effect. B) putting together a combination of proven things (intake, cam, exhaust) that will deliver performance. MY 02
Replace the entire Exhaust with the following items:
1. Long Tube Headers - this will eliminate the Precats.
2. Hi-flow Main cat or no Main cat at all.
3. Cat- back exhaust with high flow mufflers.
Vic
Pi(1.125)Squared = 4 sq" x 2 = 8 sq in for two 2" circles
Pi(1.5)Squared = 7 sq in. for a 3" circle
7 doesn't really equal 8. But -- if it's O.K. or even good to slighty increase pressure as you head to the back of the exhaust (as Vader indicates), then it would seem that the exhaust system can not be improved much without looking at headers/intake.
Vic
