L98 HP Class (102)
The exhaust pressure doesn't increase as you go back. The pressure always goes down, otherwise it would flow backwards.
The velocity also goes down, because the exhaust gas shrinks more the further back it goes. This is why mufflers don't really get you much power on a vette... because not as much air is moving through em. More CFMs go through the headers than through the mufflers.
Vader's point and your point (above) elude me. They aren't explained thoroughly enough to make sense.
It sounds like Vader recommends reducing pipe size toward the rear of exhaust (to keep velocity -- or pressure -- up). I did not see an explanation for this in here or on his website.
I'm way lost when you talk about getting power from mufflers???? I've heard some discussion about back pressure providing torque -- but even that escapes me!!! I'm guessing you're both trying to say something about backpressure, I just don't know what it is. More importantly how to consider it in a design.
Are you going to have your exhaust custom fab'd or does someone make an H pipe for true duals, w/ or w/o a cat?
I'm sure there are generic "H" pipes in 2.25" but I don't think there's one designed for the L98. I would think it would need to be "pieced" in.
Does an "H" pipe (or "X" pipe) help with noise, smoothness, or performance?
Gregg
The Insider hints book is good, but take what you read with a grain of salt. Remember TPIS uses it as a selling tool for products they sell so its very biased.
I assume you're pointing out that pressure goes down as the temp goes down (and temp goes down as exhaust travels thru the exhaust system). Vader stated that smaller pipes toward the rear helped keep velocity up.
The gas cools and slows as it travels and a larger pipe diameter will let it spread out into the pipe and slow down. You 'ideally' want the diameter to taper down slightly along the exhaust to counteract the effect, mainly so that you dont feel a loss of your low-end.
So, a big pipe will improve top-end slightly by moving that peak point higher, and a small pipe will limit the top-end because the gases cant get out fast enough and will effectively increase the back pressure in the system.
Youre not missing the point, I just dont think you are quite reading each other's posts right.
One correction to that...
Smaller pipes increase velocity. Increased velocity increases backpressure. Restrictions also increase backpressure. So... there's good backpressure and bad backpressure, just like cholesterol. The key really is finding the size that gives you a compromise between enough velocity to help with scavenging at lower rpms (increasing VE), but not too much velocity so that you have a ton of backpressure with the engine wound up to 5500rpm, so much that it will start reducing VE.
VE = volumetric efficiency and is a close indicator of horsepower.
Some backpressure is necessary. The reason I'm guessing it's necessary is that is gives the engine something to push against. Since piston engines are similar to giant pumps, fans, or blowers, they can create more power with more through-put and/or rpms. However, every action has an opposite reaction where some backward force is going to be applied. Since torque is a measurement of force vs. speed (HP?) pressure is being applied and that pressure needs something to press against. (Consider how much easier it is to push furniture across the room if your back is against a wall).
Practically applied to L98's, I'm guessing that some pretty big extremes would need to be introduced before a significant negative effect would be created. For example really short pipes larger than 4"-5"?
I my case, I own a 6-spd. I don't race, but I drive fairly vigorously. Specifically, I enjoy 1/2-3/4 throttle accelerations shifting before 4,500 rpm. With so many gears, wrapping the motor up higher seems so unnecessary. (Again, I'm not racing -- though I can't resist the occasional WOT!) This probably means I'm more of a torque lover than raw HP. That's also why I'm not sure that headers/intake work would benefit my "goals".
Though this thread contains a lot of (great) theory, I have stated my primary goal -- to update my exhaust and add side exhaust. If you have never considered this option, some thought will help you realize that our C4's represent HUGE challenges to this option. Since I'd like to keep sound levels fairly low, minimize loss of ground clearance, complete parts installation before the rear wheels, improve power (if possible), and keep or improve the emissions quality at or above where it is, I have a difficult task. Think about it!
I will also be installing a high-rise hood (current one is damaged). So, in the future, I could go crazy -- if I wanted to. But gas ain't cheap, parts aren't cheap, rebuilding motors ain't cheap, and I enjoy the car at it's current power levels. While improvements in power wouldn't go unused, I'm more focused on gaining the unique (yet utterly "Corvette") character of side exhaust.
I'm glad I'm learning about general theory while I'm also looking to apply that knowledge to immediate plans. (Keep in mind that the right comments COULD gear my goals more toward power vs. style if I thought it were reasonable to attain. So I'm also being open-minded!)
Gregg
IF I put headers on my vette, I'd be interested in keeping the sound levels down. I'm already putting a heftier sound system (than the Bose) in my car because the Bose didn't cut it. So, I wouldn't want exhuast that would overshadow the tunes.
It would be O.K. it "spirited" or WOT driving created sound levels above the music but I wouldn't want SIGNIFICANT resonance present all the time.
In my quest to install side pipes, cats and mufflers would have to be installed in front of the rear wheels. Can this be done while meeting the sound level requirements I've outlined? EVERY car I've heard with non-factory headers has been pretty loud -- louder than I'd want. However, since the goal of headers is to gain HP, I can understand that.
More importantly, this raises the issue of reducing backpressure (to get more HP) vs raising sound levels. My instinct is that there must be a direct trade-off between "opening" up exhaust and increasing sound levels. It would seem intuitive that less back pressure would mean less sound muffling. My conclusion would be that headers and dual exhaust with small high-flow cats and high-flow mufflers would be louder than I'd want.
What do you think?
We just got good news. As of Jan 1 2006 no more e-check in Ohio. WOOHOO!!
My car with Power Effects in the closed position will resonate at 2000rpm, with them open its at a different pitch but still there. I can hear the Bose just fine over the exhaust at other rpms, but on the hwy its bothersome.
A reason why coupes resonate is because of the big sound chamber you have behind the driver, and the exhaust underneath exiting directly below it. Thats why you can put extensions on the pipes, and add crossovers to reduce resonance on coupes. I have no idea what will work for a C4 with side pipes though. I have only heard one once before.
Exhaust is one case where bigger isn't always better. I could show you some fittings that flow better when reducing the pipe size and worse when increasing it. The best lesson in air flow, is that it can be very counterintuitive. Lots of self-proclaimed air flow experts in here, including me, so be careful with what advice you take to the bank.
Sell the tornado and save money for nos or drag radials. The tornado doesn't have any effect on the TPI. The 03 cobra can beat you by a full second unless he doesn't know how to drive a stick. I treed an 04 cobra in my 85, but he couldn't drive at all.
hehe second vette in a year totaled the first one racing lol but anywayz i need somethinig fast i cant use nos im on my second engine and it might blow it i got 6 days now till the racce adn I CANT LOOSE drag readials rnt good either lol my cars got new tires kumos and it slides on dry asphalt and i cant even take it in the rain its so bad well more help needed aprreacate the thoughts
hehe second vette in a year totaled the first one racing lol but anywayz i need somethinig fast i cant use nos im on my second engine and it might blow it i got 6 days now till the racce adn I CANT LOOSE drag readials rnt good either lol my cars got new tires kumos and it slides on dry asphalt and i cant even take it in the rain its so bad well more help needed aprreacate the thoughtsYou're on the wrong forum then, and Mojo will lock down your threads on stuff like that. Go here: Corvettekillstories.com
Try and stay alive.
btw, Mine's an 85 with 6 speed swap, stock motor with small stuff done to it, I figure it's got about 250hp, best ET is 8.91@82 in the 1/8 mile. Have you been too the local dragstrip yet? You should definitely try it out, you might enjoy it more than street racing. And crashes are rare. Tickets and impounding are nonexistent.
that wuz some of the best *** rapings a mustangs ever seen
puts a big smile on my face but thething u said abouta stick being faster my friends got a 98 stang with flows on it...its a 5 speed but i whoop him really bad......but he can drive a stick really well been doing it since he wuz 12(4 yrs) but its a six banger so idk if thats y or not
whats a mojo locking thread if u dont mind me asking
