OK, here is one of those things I have always wondered about. If my engine is sitting here idling at 25 PSI of oil pressure than how does it keep my lifters pumped up against a valve spring that not only has a leverage advantage on it because of the rocker arm but has over 100 PSI when it is in the fully closed position? I think I know, but I need to be sure. Inquiring mind and all that stuff.
Roy
When the lifter moves up the bore and it is experiencing valve spring preassure, the oil feed hole is blocked off by the bore and the lifter is like a solid lifter because no oil can leak out and the oil is not compressable.
The only time the lifter feed hole is exposed to the oil preassure is when it is down the bore, off the cam lobe, and the oil preassure simply acts on the lifter internals to tale out any slack in the valvetrain when there is NO spring preassure to contend with.
It is neither the size of the internal spring or the size of the hole in the lifter
Hope this helps
Jerris
Hope this helps
Jerris
Great explanation, it simply describes a complex mechanical event!
