Inside Rocker trim panel removal
Old Jan 14, 2006 | 08:17 PM
87vetter's Avatar
87vetter
Default Inside Rocker trim panel removal
To remove the inside trim panels at the rocker area below the door.
The panel has a few screws that attach it to the body. Where are the clips located and what is the best way to release them so you do not damage the molded panel. This is the carpet sill, inside of car.
Old Jan 14, 2006 | 09:09 PM
DarkBlue88's Avatar
DarkBlue88
From: Charlotte NC, behind someone going 10 under the speed limit
I'm not sure if you're talking bout the carpeted sills or the lower panels, If the lower panels, I'd like to know also for a repaint.
