Tire size question
Old Jan 15, 2006 | 07:53 PM
rickslt4's Avatar
rickslt4
Default Tire size question
I've searched through the archive to no avail so I'll ask again. I've read somewhere that i can put the same size tire on all corners of my 96. Is there a big advantage to this other than being able to rotate them? Will I rub in the front? I'm running stock 17x9.5" rims.Thanks guys
Old Jan 15, 2006 | 07:56 PM
rickslt4's Avatar
rickslt4
opps, I'm running 8.5's in the front and 9.5's in the rear.
Old Jan 15, 2006 | 08:13 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
Luke at tirerack answered that specific question a few months ago for me. He said, in answer to my question re my all 4 9.5" wheels that 275-40 will be fine. A few have said that 285-40 will also work. I'm likely to go either the 275 or standard route (255-45 front, 285-40 rear).
Old Jan 15, 2006 | 08:33 PM
biggrizzly's Avatar
biggrizzly
2015 C5 of Year Finalist
I'm running 285s on 9.5" wheels on all four corners with no rubbing what so ever.
Old Jan 15, 2006 | 11:16 PM
MYCoupe's Avatar
MYCoupe
Putting 275s up front will probably reduce understeer a little bit. However, you really need 9" wide wheels to run 275/40/17 tires. Some guys have put 275s on the 17x8.5" wheels, but I don't recommend it. Get yourself another set of 17x9.5" sawblade wheels, which are relatively cheap, if you want to run the same size all around.
Old Jan 16, 2006 | 12:58 AM
David Mark's Avatar
David Mark
I just switched from 17 x 8.5" in the front to 17 x 9.5" in the front. I also went to 17 x 11" in the rear. No clearance problems. I was tempted to stick with the 9.5" width all the way around for the rotational reasons too, but I always seem to encounter a road hazard on some tire before significant wear occurs. Then I end up replacing both fronts, or both rears...
Old Jan 16, 2006 | 09:50 AM
Red_Vette_93's Avatar
Red_Vette_93
I'm planning on putting 18 x 9.5 all around with 275-35-18...that should stick pretty good.
Old Jan 16, 2006 | 11:45 AM
JEFNLSA's Avatar
JEFNLSA
Ditto that...and my car is lowered.
To Tire size question
