85...new motor, won't idle
The new engine is a 409 with a burnett made super victor intake setup, factory ignition and factory throttle body.
The car will run fine if it is running at higher than normal speeds (foot on pedal). But if you let off, the car just dies.
Is this due to the fact that I have the factory throttle body (unchanged) on this bigger engine, or is it something like a bad IAC???
What about the tune? It may require a larger IAC opening to make the larger engine idle. You can cheat it by cracking the throttle blades a little bit.
Yeah, forgot to include that. I had Jesse Azzato make me a new chip to mate with the new motor. What is a Min Air Adjustment???
I didn't get a chance to get a light on it this time. Also have no idea where to begin timing the damn thing.
How do I know if it requires a larger IAC opening??
IAC diagnosis from my manual http://members.shaw.ca/agent86/IAC%20Diagnosis.pdf
Believe me,im not trying to insult you or put you down,Ive read this entire thread and you do not know what the basics are to get a car running right when its fuel injected.Yes we are here to help..and we will do what we can to help.Its a learning process we all went through,but if youre going to drop a 409 into your engine bay and its efi,you better have a scanner,a lap top and alot of basic knowledge of how fuel injection works.
If you dont youre going to ask alot of questions and blindly try to fix your car and not know why it isnt doing what you need it to do.
EFI and/or TPI sint hard at all,just takes a bit of time to learn how it all works together,prom,sensors and all.
A great book I suggest for the learning is:
http://www.corvettebookstore.com/Pro...tails_7206.ncm
Again please dont take this as a personal insult.I had to assume what I did from your post and responses.If someone else is doing the work and need your info from here,they need to learn some more as well.
So in short, I am going to ask alot of blind questions. And as long as people are kind enough to answer them, I'll keep trudging on.
