Shift points (video)
Old Aug 6, 2001 | 10:01 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Default Shift points (video)
I shot a video of my tach. It's a little blurry and there is no sound(sound card is screwed up), but you can see where I shift and how much(or little)the rpm drops between shifts.
http://www.corvetteforum.net/c4/mrmojorisin/Tach1.mpg
Old Aug 6, 2001 | 04:17 PM
Mr Mojo's Avatar
Mr Mojo
Default Re: Shift points (Mr Mojo)
:crazy:
Old Aug 6, 2001 | 04:28 PM
MY 95's Avatar
MY 95
CI 2-3-4-5-6-8-9 Veteran
St. Jude Donor '05-'06-'07-'08
were you hitting the rev limiter, it looked like you hit 6k??
Old Aug 6, 2001 | 04:39 PM
edwards's Avatar
edwards
Good video. High RPM's. Never hit that high with my auto.
:cheers:
Old Aug 6, 2001 | 04:40 PM
Dan Parker '96's Avatar
Dan Parker '96
Looks like our Mr. Mojo was doing a bit of "power shifting". For the newbies that means leaving it floored between shifts (letting the limiter worry about max rpm). This helps with times but is hard on equipment.
Old Aug 6, 2001 | 05:22 PM
Dean McManis's Avatar
Dean McManis
Mr. Mojo,
That was fun to watch.
What are your gears? 3.45, 4.09? it did seem to be quick between the gears.
Were you powershifting?
thanks,
-Dean.
Old Aug 6, 2001 | 08:38 PM
Mr Mojo's Avatar
Mr Mojo
Yes, I was powershifting and no, I didn't hit the rev limiter at all. Goes to show you that the factory tach is off, by how much who knows.
3.45 gears.
Old Aug 6, 2001 | 09:15 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
I found the stock tach to be almost 500 rpms off.
The most interesting thing about the video was the rpm dropoff between shifts.
Good job, Frank
ps, did you have Chris in the back taking those shots? :D :D :D :D :D :D
Old Aug 6, 2001 | 10:04 PM
hi-tek-vette's Avatar
hi-tek-vette
Default Re: Shift points (My 95)
thats quite a large drop in rpm's , gear to gear ..... i assume you get no tire spin at all, eh ?
Old Aug 7, 2001 | 01:01 AM
Mr Mojo's Avatar
Mr Mojo
Default Re: Shift points (hi-tek-vette)
No tire spin at all
Old Aug 7, 2001 | 01:24 AM
XtremeVette's Avatar
XtremeVette
Original Founding Member!
Cruise-In 1, 3, 9. 10 & 11 Veteran
hey...Mr Mojo....my automatic looks just like...that...tach even does the same!!!......pegs the plastic....on near the middle just like yours....dude.....only thing...you look faster on the acceleration after about 80....my L-98 seems a bit slower there....but was curious dude...what was the time....you ran on that recorded run....I tried to calculate it...but my calculations are coming out a bit slow for you.......0-60 in 5.6 and looks like a 14 quarter.....but thats just me trying to calculate it from the video......
thanks dude for the show...!!!!
[Modified by XtremeVette, 11:25 PM 8/6/2001]
Old Aug 7, 2001 | 08:28 AM
Mr Mojo's Avatar
Mr Mojo
Default Re: Shift points (XtremeVette)
Hey Jeff, that particular run was terrible, I only ran 13.82 on that one, you can't see, but my temp was up to 220!
Old Aug 7, 2001 | 10:18 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
If I waited that long n the '92 I would be all over the rev limiter. Just goes to show you how far off the stock tach's can be. Good show Frank ;).
Old Aug 8, 2001 | 12:30 AM
Thud's Avatar
Thud
Default Re: Shift points (Vette92)
My rev limiter kicks in when the tach reads about 5900 so it's just a couple hundred rpm high. But my tach needle is kind of "bouncy" over bumps which is rather annoying.
Old Aug 8, 2001 | 08:50 AM
MY 95's Avatar
MY 95
Default Re: Shift points (Thud)
i hit my rev limiter once with the tach showing 5800 and i have the same year and setup as Mr MOjo does
Old Aug 9, 2001 | 09:28 PM
Duntov's Avatar
Duntov
Of the few times that I have hit the rev limiter, I have seen about 5900. I have never seen it go beyond 6000.
Old Aug 9, 2001 | 09:54 PM
Corvette Kid 92's Avatar
Corvette Kid 92
Default Re: Shift points (Duntov)
very :cool: ive never tried powershifting b4
To Shift points (video)
Old Aug 9, 2001 | 11:22 PM
95vettski's Avatar
95vettski
Default Re: Shift points (Corvette Kid 92)
:cool:
Old Aug 19, 2001 | 02:06 AM
Mr Mojo's Avatar
Mr Mojo
Default Re: Shift points (95vettski)
:seeya
Old Aug 19, 2001 | 08:54 PM
cohocarl's Avatar
cohocarl
Mr Mojo,
How could you tease us like that.........NO SOUND????? :cry
[Modified by cohocarl, 7:55 PM 8/19/2001]
