instrument cluster problem
Old Jan 19, 2006 | 11:41 PM
hute''s Avatar
hute'
6th Gear
Default instrument cluster problem
having my instrument cluster goes intermittent for 30-45 seconds and then works normal, when intermittent it goes int a lost in space kinda mode the whole cluster segments and flashes weirdly any ideas / stuck scratching my head p.s 1986 model
Old Jan 20, 2006 | 12:06 AM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
No car year info provided, but I'd probably make the same suggestion.
There's gotta be a main plug that connects to the back of your cluster. Remove the cluster, unplug the connector, clean contacts, check for lose wires, and replace. (Do not retighten until a few days passes).
I suspect you're losing contact through this connector which is causing your entire display to flake out.
gp
