OK guys,
I am selling my blue 91 to a guy in arkansas tonight and hes on his way here to pick it up.I pulled the car out and the bose radio isnt working.I drove the car thursday and it was working fine, now it dont light up or anything.I can push the top button and the clock will light up and it will still accept and eject cds but theres no light and no sound at all.
I have another head unit here that I know for a fact works so I put it in and still the same thing.I Checked all the fuses and the wiring behind the deck the best I could and I couldnt find anything wrong.I wiggled all the wires under the passenger dash and watched the radio to see if maybe I had a bad connection somewhere but again I got nothing.
I need to figure out whats wrong with it in like the next 2 hours....please if anyone has any ideas let me know....
OK guys,
tia......Al
Ok I got power to the fuse in the main block but no power to the little block under the passenger side. also got no power ant...when I turn the running lights on I got all the lights on the radio to light up to....maybe a bad connection or something......
I checked every fuse in the car and pulled the glove compartment out and inspected all the wiring....I have not found anything...everything else in the whole car works fine but the radio....I have no sound what so ever but i do have lights on the radio when the running lights are on and if i push the clock button the clock lights up....is there a relay or something somewhere?????oh ya i dont have a power antt. eother.
I'm only familiar with my 86 but on mine one fuse is responsible for the power to the antenna relay and bose amp relay. When that goes bad i have no sound and no antenna but lights etc on radio work.
I would test the fuses rather than give them a visual. I have schematics for 86 only so hopefully someone else can step in with the info you need.
The radio fuse is good in the main block.If i pull it I can not turn the clock on, the ant,csty fuse is good also. the only fuse I found that didnt have any power to it is the fuse under the dash in the small block where the fuse for your security system is.I checked the block itself and it doesnt have any power to it for the radio. i guess this would be the fuse for the amps also???
well that website help a bit...thank you...I still dont get forsure why the heck i dont have any 12v power to the stereo or amp when the fuses are not blown.I AM ON MY WITZ END! I did not sell the car because the buyer didnt want the hassles with the electrical issues....now I have to fiddle with it to get it fixed and then I have to go back and advertise the dang thing again.
anyway guys I appreciate all your help and tomarrow morning I am going out to tear into this thing.I am going to go through the whole harness if I have to.does anyone know what exactly are the wires that supply the 12v constant and switched to both the amp and head unit? also if theres any wires that run to the ignition?
tia again.
Al
Did you check the "CDM box" (whatever the heck that is) like they suggest on that site? That is their first step to do for no power.
If the clock is keeping time, don't fool with the 12v constant wire, that is good. Shouldn't be any stereo wires going to the ignition...its power is tapped off of a 12v "switched" circuit on the fuse block.
ya, I am thinking its the main amp (cdm box).....I am going to check that tomarrow but I just dont see why that would cause me to have no power to the head unit.I meen I have power but no display or sound.just display clock and lights around the buttons when the running lights are on.asnyway wish me luck....the bose system sux!
bogus,
Can you tell me what wires on the cdm box and at the back of the stereo suppy power.I know i have 12v constant because the clock keeps time but I dont have any sound at all or a display for the radio or cd.when I turn the power on to the deck It dont even click or turn on the power antanna.I am going to go through and check all the wires to make sure its getting the correct power.I dont have any idea where the relays are or if indeed there are any. I was reaging somewhere that the only relay is in the cdb box but I am not 100% sure about this.anyway all your help would be very appreciated......thanks again.Al
ok well I pulled the cdm out today and checked everything out.the box itself dont have any burnt smell to it and I know that I have a 12v constant from the box to the radio but I have no idea what wire would be the 12v switched.I am in desprate need of getting ahold of the wiring diagram for this thing.I have checked every fuse in the whole car about 10 times and I checked the power to the little buse block under the dash and it was fine.I guess I need to find out which wires on the back of the radio are the lead power wires and trace them to the problem. If anyone knows what wires are what on both the cdm and the radio please let me know.thanks
ok... I am back... sorry for the delay, it's been a cwazy day!
Orange - hot at all times
Brown - battery power in - after harness, turns red/yellow
white - ignition in - after harness, pink
dk blue - ground in - after harness, black
blue/black - +14v - after harness, purple/yellow
Start checking there.
I will scan these pages tomorrow... I need to reinstall the scanner software before I can do it. oops.
ok heres what I got off the back of the deck.I also checked the ground wire and it is good.from what I can tell I think the ign. wire is bad somewhere...? anyone else have any ideas?
red/white= 12.11v key on and off
green=10v on and off
orange 12v on and off
green and white=5v on and off.
I checked every wire 3 times with a volts meter to make sure I didnt miss any. I didnt not get any power from the pink at all and I saw a solid purple(no power either) but no purple and yellow..
thanks ang hopefully I can figure this thing out since electronics are not my specialty. thanks guys
