Back to Valve Cover Question
I still have to order cam, rocker arms, lifters and pushrods for my engine build up, and want to make sure I get the right combinations of parts that fit and work together. After searching and reviewing all the past threads on valve cover clearance, one thing that I can definitely say is, which valve cover will clear, for what application is clear as mud.
I would not mind putting polished aftermarket valve covers on the car, but I'm afraid of clearance problems under the alternator bracket up front on the left bank. Also, I'd like to retain the crankcase breather on the inside of the right bank valve cover. If I knew unequivocally that there was such a cover, I’d order them now.
Alternatively, if I knew unequivocally that a specific 1.6 rocker arm would fit under my stock valve covers I’d buy those and retain my stock valve covers.
If anyone can identify either a specific 1.6 rocker that will fit under the stock covers with minor modification (I’m not looking for “it might work” or “keep cutting until it fits”) please let me know.
If anyone can identify a taller valve cover that will fit under the alternator bracket and be drilled or has provision for the crankcase breather hose let me know.
Thanks in advance
More experiences please?
Thanks in advance
On the Driver side you will have to grind on the back side of the alternator to clear the Proform valve covers. Once it fits the part you grind is out of sight. You also need a washer or two between the alt brace and the intake manifold.
I need to redo my web site and get it loaded to Verizon so I can post pictures. It does all work, and it looks like the pieces were made for the car.
Actually I can upload a couple pictures to putfile right now. Give me a few.
Alternator fitment with Porform
Passenger side crankase breather
Engine bay long view
http://putfile.com/pic.php?pic=1/2110203023.jpg&s=x4
The part number for the hose I'm not sure about from the desscription on the receipt : 22048212. For sure it is a crank case breather hose for 92 Vette, a formed length of hose. Call to make sure you get the right thing.
Fred
On the Driver side you will have to grind on the back side of the alternator to clear the Proform valve covers. Once it fits the part you grind is out of sight. You also need a washer or two between the alt brace and the intake manifold. [/QUOTE=FELNGR8]
I'm doing the same...
I hope this helps, the Proforms are a GREAT looking valve cover...
Mo
