Disturbing find
I picked up a tank of bad gas and needed a reason for a long cruise to run it out.I have read some threads about the improvement after changing the coil I thought I would head down to Summit Racing and pick up a new MSD Blaster and try it out.
So I get home start looking over the job.I hate these old connector clips they make me nervous and i remove them without incidence.When I removed the coil wire white powder went everywhere
The cap and coil plug were coated like a 10 year old battery terminal
I got the electric cleaner out did the boot up and looked at the coil.It had major damage on the plug where the arcing was occuring it vaporized large holes in it.
After putting the MSD coil in I di electric greased(my mistake the first time) the cap and tried to put it on.It would not snap on.HMMM the real problem now.It was too big from the start and needed squeezed probably was like that when I put it on the first time.
So all is well now new coil works great, TV static is gone ,another spot that my previously leaking intake drenched is clean.
