90-91 tach filter?
Old Jan 22, 2006 | 07:09 PM
ar91c4's Avatar
ar91c4
Default 90-91 tach filter?
Does anyone know where I can find a 90-91 tach filter at?I have tried ecklers and the local dealer ship...
Tia,
Al
Old Jan 22, 2006 | 09:07 PM
corvette1990's Avatar
corvette1990
I know you will get conflicting advice on this subject. However, I bought my 1990 NEW, and even saw it built. Therefore with authority will tell you my 1990 L98 had NO tach filter. I thought I was having a tach filter problem because my tach on my dash was reading alot higher than it should be. Thats when after being advised here to install a new filter, I found I did not have one. I replaced my Gauge cluster and the problem was solved. If you had one, it would be about a foot from the distributor close to the drivers side firewall. (on the white wire I think). That is why Ecklers or GM does not sell one.
Chris
Old Jan 22, 2006 | 09:29 PM
ar91c4's Avatar
ar91c4
I have a kinda square little box off the tach input about a foot down in the harness.I have done a little research on it and it looks like the filter on the 92 on. its not the barrel type filter.I am wondering what would happen if I just removed the filter? also if that didnt work would the one off a 92 work?
thanks again
Old Jan 22, 2006 | 09:42 PM
Sandrider's Avatar
Sandrider
St. Jude Donor '05-'06
I saw that little black box on mine too.....
My tach is acting up....
Old Jan 22, 2006 | 09:43 PM
GreyHairedTopGun's Avatar
GreyHairedTopGun
Default 89 Tach Filter
When I get on it hard, and fast, the tach on my 89 tops out about 35-3700. I was told this was the tach filter. So now the questions are, do I have one, if I do where is it, if I don't what do you suggest?
Thanks guys.
Old Jan 22, 2006 | 10:14 PM
hippy's Avatar
hippy
Thanks guys.
Do you have an aftermarket coil? My guess is you do and that is your tach problem.
Old Jan 22, 2006 | 10:27 PM
Slalom4me's Avatar
Slalom4me
The '89 came with an OEM filter. If you locate the terminal on the
Dist Cap marked 'Tach' and follow the white wire out of sight behind
the driver's side head you will feel the Tach Filter. Look closely
between the head and firewall and you will see another white wire
passing through a male/female connector before entering the harness
bundle.
Mid America carries filters: there is one style for the pre '84 and a
different style for the '84-'89.
If Hippy is correct and you have an aftermarket ignition or you are
using an aftermarket tach, then you might want to check with MSD
to ask about which of their Tach Adapters (8910, 8913, 8920 or ...)
might be suitable for your requirements.
Old Jan 22, 2006 | 10:40 PM
ar91c4's Avatar
ar91c4
what about a 91`? and what happens when you dont use one?
NT Vettman's Avatar
NT Vettman
I have the factory electrical service manual for 1990 and the wiring diagram shows no tach filter. The white wire comes from the distributer directly to the instrument cluster, all white wire. The sevice manual has a brief mention that the signal is produced by the ignition system. It dosen't mention any servicing of the tach it's self. If the tachs in our cars are off or wrong I would belive that the instrumet cluster would have to be replaced.
Old Jan 22, 2006 | 10:47 PM
ar91c4's Avatar
ar91c4
true, but i have both a 90 and 2 91s. both have tach filters.the 91 has a 92 and up style filter.
Old Jan 22, 2006 | 10:48 PM
skateparkdave's Avatar
skateparkdave
Chris
Not sure what it's purpose is, I just know my 90's tach is working great without it. I replaced the instrument cluster with a GM refurbished unit when I had tach trouble and now my tach works great, without the filter.
Here's mine not serving much purpose.
Old Jan 22, 2006 | 11:05 PM
Red Tornado's Avatar
Red Tornado
when the tach in my '90 went haywire, i replaced the tach filter with a used one i bought from a salvage yard. the problem was corrected with the replacement filter.
by the way, the tach filter in 90/91 is specific to those years. they are out of production and unavailable new, anywhere. the only means of support right now is via a salvage yard (and most likely will remain that way forever).
i still have my stock ignition.
Old Jan 22, 2006 | 11:10 PM
ar91c4's Avatar
ar91c4
that realy sucks!well i guess i will try it without it...then go hunting in the phone book!
Old Jan 23, 2006 | 02:14 AM
corvette90's Avatar
corvette90
i found this..i built the curcuit, but havent tested yet...
http://www.corvetteforum.net/c4/marc...achfilterj.jpg
i too have a 90, tha tach reads high at idle, about 1200rpm when idling with 800, more interesting, when i rev the engine, tach stops at 4000rpm, and when i shift, it jumps around ....
Old Jan 23, 2006 | 06:53 AM
mseven's Avatar
mseven
www.rodneydickman.com/CorvetteTachFilter.html
You can try someone like this, the filter should reduce the spiking in the line. When I asked this quite awhile back many told me they removed with no problem.
The intersting thing here is when I went to get a part number for it, the GM dealer pages show no part there ???
Old Jan 4, 2020 | 03:09 AM
Rico Muñeco's Avatar
Rico Muñeco
Cruising
Default Tach filter
Ironically my factory sevice manual for my 91 Coupe does have the tach filter in the wiring diagrams. I also physically have one behind the left cylinder head. So i don't exactly know what or why there are differences with some, but i have seen this many times in which some have something & others don't, & they can be the same year & model. The only thing is possibly when in that year it was built. For instance, some having certain things found on models from the following year & some the previous & even odd mixtures of both. Most commonly with the 91, & then 90. Being these are the 2 odd ball or unique years in major changes from the past or to the future. Also isolated with these 2 years only parts.
Old Jan 4, 2020 | 10:30 AM
vettespecial's Avatar
vettespecial
Default Tach filter
My 1990 tach was inaccurate reading 1500 rpm from actual, .before I pulled the engine. after engine installation it stopped working completely, I went to check tach connection and found filter wire broken. Ordered a new one form Zip corvette installed it and still no tach reading.
pulled out the cluster using a digital volt meter set to AC volts with engine running checked voltage at terminal B10 I read 6VAc so signal was coming in to tach but not working. Sent it to bantee.com for replacement he's very knowledgeable he changed out all the bulbs cleaned connections and replaced a electronic filter inside the cluster. After reinstalling it's been working great.
Old Jan 4, 2020 | 11:25 PM
aklim's Avatar
aklim
IIRC, my 91 had a tach filter. It got cut off when I replaced the plugs to adapt the system to the small cap distributor.
To 90-91 tach filter?
