EM header question
Old Jan 25, 2006 | 08:16 PM
fredk's Avatar
fredk
Default EM header question
Got my headers on and the O2 sensors. While I was under the car I noticed that the oil filter is really close to the header, really close. I hope it will be an easy oil change. Secondly I was also putting on my plug wires, 6 with 90's and 2 straight. Where are you putting the 2 straight ones, or should they all have 90's.
Fred
Old Jan 25, 2006 | 09:17 PM
aboatguy's Avatar
aboatguy
On my LT1 with EM Long tubes oil changes have not been a problem. As for the plug wires I reused the wires and looms that were already on the car.
Mike
Old Jan 25, 2006 | 09:42 PM
fredk's Avatar
fredk
Mike
I saved my original wires and they are also 6 90's and 2 straights.
If that is what you used, which cylinders did you put the straights on???
I want to avoid melting the boots.
Fred
Old Jan 25, 2006 | 09:59 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Originally Posted by fredk
Mike
Fred
My MSD wires came with two straight boots that located on the two rear cylinders on the RH side, I'm not sure why. It worked okay with manifolds but when I switched to headers, it was much more practical to change those two to 90 degrees, which is what I did.
Jerris's Avatar
Jerris
The two straight ones go on the back two plugs on the passenger side of the engine.
Jerris
Old Jan 25, 2006 | 10:12 PM
C4Crazy787's Avatar
C4Crazy787
Jerris
http://forums.corvetteforum.com/phot...tud_Rt-med.JPG
Old Jan 26, 2006 | 06:21 AM
fredk's Avatar
fredk
Thanks guys !!!!!!!
To EM header question
