Compression question
Old Jan 25, 2006 | 09:57 PM
MR NICE's Avatar
MR NICE
Default Compression question
Hi,Can anyone tell me what the compression ratio a 58cc head on a stock 85 would be ?What type of piston?, flat top, dished?size of valve reliefs? Thanks for any help.
Old Jan 26, 2006 | 10:17 AM
q2blaster@work's Avatar
q2blaster@work
the 85 has a trw forged flat top w/ one valve relief going across for both valve's
without calculating I would say 10.25-10.5, just a guess but probably not to far off.
Old Jan 26, 2006 | 11:05 AM
newcastle3's Avatar
newcastle3
St. Jude Donor '10
There was a thread a while back where I asked the same question, I'll have to find it, but if I remember correct it was around 11:1 or a little bit higher.
Edit:
This was the thread I mentioned.
http://forums.corvetteforum.com/show....php?t=1267605
Old Jan 26, 2006 | 11:38 AM
CFI-EFI's Avatar
CFI-EFI
I forget the final answer, but if you make some assumptions, you can figure it out, yourself, pretty easily. The '85 has a 9.0:1 compression ratio. If you can accept that spec as fact, knowing that the 350 has a 4.00" bore and a 3.48" stroke, you can work backward to figure the above piston volume at TDC. Subtract the 18 ccs, (the difference in the stock 76 cc heads and the 58 cc heads you want to install), from the above, figured above piston volume at TDC, and re-figure the compression ratio. That way you don't have to know a lot of sometimes difficult to obtain figures, like piston valve relief volume, etc. This method DOES assume the same head gasket volume, but you can adjust for that, too, if you have the numbers. Simple, EH?
RACE ON!!!
Old Jan 26, 2006 | 04:02 PM
MR NICE's Avatar
MR NICE
Thanks,is 11to 1 safe with 93 pump gas?I think I'll go with 64 cc. to be safe.
Old Jan 26, 2006 | 04:22 PM
CFI-EFI's Avatar
CFI-EFI
Is it safe? It all depends. There are many intervening factors.
You can go through the same exercise, I described above, for 64 ccs, also.
RACE ON!!!
Old Jan 26, 2006 | 08:26 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Check out the this compression calculator, there is a free demo version
http://www.performancetrends.com/download.htm#crc
Old Jan 27, 2006 | 03:38 PM
q2blaster@work
http://cochise.uia.net/pkelley2/DynamicCR.html
http://cochise.uia.net/pkelley2/crc.htm
http://www.crossedflags.com/nuke/htm...wtopic&t=15687
To Compression question
