What does it take to clog a cat?
86' see mods in profile.
Thanks for any info in andvance
However, what happens to kill a cat (and no kittah jokes
):1) It gets physically hit... speed bump, running over things... anything that can damage the matrix inside.
2) raw fuel. it comes out and cools the surface of the cat, causeing it to melt into a mass of stuff.
3) lead additive. this will cause the cat to be totallt blocked in no time flat.
And that too will kill the cats (as well as the pistons) due to the increased heat
ok, im lean if thats the case, Im reading this a/f ratio wrong.
So why is it that the exhaust stinks/stinked so much?
And how can I tell if my cat is damaged? and s this a number that cold damage the cat?
Sorry for so many questions
Carl "the field biologist is showing" Johansson
RACE ON!!!
But I do know if it is bad enough and recurring it can be a bad sign.
Cooling causes melting? Now there is an intriguing concept.
RACE ON!!!
and I qualified the 16 number as being something I didn't know the answer to a few posts above.
dumping raw fuel into his cats he clogged them-if you're doing the same thing-find out WHY-before just throwing $$$ at it and replacing a cat(s) cats are made out of precious metals (at least earlier cats such as ours-platinum-if memory serves correct) a honey comb design! by your ratios-if correct-sounds lean-by your NOSE-sounds rich, be sure!
And the only way to find out is to pull it out and look...
RACE ON!!!
I will explain each:
PHYSICAL DAMAGE: 80% of completely clogged cats are caused by them getting hit physically, mostly on speed bumps, or a loose hanger causing them to shake excessively over bumpy roads. Although the membranes inside the catylatic converter are protected by a thermal blanket, technology of the substrates on which the active catalyst is supported has seen great progress. In 1974, ceramic substrates had a density of 200 cells per square inch of cross section (31 cells/square cm) and a wall thickness of 0.012 inch or 12 mil (0.305 mm). By late 1970s, the cell density had increased from 300 to 400 cpsi and wall thickness had been reduced by 50% to 6 mil. Then 400, 600 and 900 cpsi substrates were available and wall thickness had be reduced to 2 mil - almost 0.05 mm. In the the middle of the 1980s, substrates derived from ultra-thin foils of corrosion-resistant steels came on to the market. In the beginning, the foils could be made from material only 0.05 mm thick allowing high cell densities to be achieved. Complex internal structures can now be developed; 800 and 1000 cpsi substrates are available and wall thickness is down to 0.025 mm.
As you can see, depending on what year your car is, the substrate membrane internally can be easily damaged. This is the ONLY thing that will cause chunks to be loose inside your cat. If you hit the cats with something like a broom handle and something rattles, it is from physical damage. ( A rich mixture does not cause the pieces to break apart)
POISENING: This is the second most common cause of clogged cats as the contaminates cannot be burnt so they stick to the substrate membrane and build up to the point of clogging the passages.
Common poisons are : Leaded fuel, silicone, gasket sealers, some fuel additives, loose rust and exhaust paste.
The normal operating tenperature will melt these contaminants and they will clog the passages inside the cats
The following steps will minimise "poisening" the cats.
1. When fitting the catalytic converter, don't use exhaust paste in front of the cat. When the exhaust paste hardens it can break off in small chunks and due to the velocity of the exhaust gases, damage the monolith. Paste can also block the monolith.
2. Always use the correct fuel for your car.
3. Never use a fuel additive without first reading the instructions to find out if it is suitable for use with a catalytic converter. If in doubt, contact the manufacturer of the additive.
4 Use extra care with silicone based sealants around the intake manifold , as these can be sucked into the engine and out the exhause to the cats.
5. Additives in oil that is sucked pass the rings into the compustion chamber and out the exhaust can poisen the cats. Ensure that any oil addetives you add to your oil is compatible with cats.
6. Loose rust reaching the cats cannot pass through the small openings in the honeycomb or between the pellets. Remove loose rust from inside the exhaust pipes ahead of the cats when fitting new cats by tapping the pipes with a hammer and briefly starting the car.
EXCESS FUEL While it is possible to completely block the cats due to excess fuel, the process by which this happens makes this the least likely cause. Excess unleaded fuel by itself does not affect the catalysts within the cats. Excess fuel burning inside the cats can in, rear cases, melt the insides of the cats, however there is usually physical damage to render the pieces small enough to melt.
The reason this is rear is that there are so many warning signs before melting that the problem is ususlly diognosed and corrected, long before the cats are completely plugged.
These warning signs include:
1. The O2 sensor will be the first sign and will throw a code because there is unburnt fuel in the exhaust. The O2 sensor will also send the ECM a message to reduce the amount of fuel from the injectors resulting in a general loss of power from the engine. Unless of course the O2 sensor is bad.
2. If the O2 sensor is bad, and the injectors are dumping, (stuck open) the unburned fuel will reach the cats. Providing your air pump is hooked up to introduce more air (oxygen) into the cats (exhaust), the excess fuel will burn inside the cats. However the high tenps (2500 to 3500 degrees) needed to melt the substrates, which are made of either Ceramic or Metal and is coated with precious metals such as Platinum, Palladium and Rhodium, will usually severely discolor the casing of the cats, damage the floorboards of the car or pass alot of heat into the car, warning you that something is wrong with the cats long before complete clogging from meltdown.
3. If you do not have an airpump the excess fuel from a hung up injector will not burn off inside the cats due to a lack of sufficient oxygen, and it will pass out the exhaust as a gas with a strong smell of gasoline. This will not damage the cats at all.
4. A gradual loss of performance due to partial clogging to the point that there will come a time when you will press the gas and the car will just not go any faster.
LEAN MIXTURE While a lean mixture will result in elevated temperatures within the engine and exhaust, it will never be hot enough to melt the materials within a catalytic converter, which are designed to operate at very hot temperatures (see above). The new materials in cats have allowed car manufacturers to move the cats forward to right next to the exhaust manifold because the hotter they are the better they do the job of removing pollutants. Due to warrenty they would never do this if temperatures that an engine is able to operate at (even when lean) had any chance of melting the innerds of the cats.
I know there are people on this forum that will argue that excess fuel will quickly clog the cats, however my research does not support this theory. This is a slow process that takes some time and has alot of warning signs.
I have also notice that there are many people with genuine questions who want to know how the catalytic converters works and how it affects performance.
I have lots of research on this I can pass on as, being a car nut first, I did a paper on the automotive catalytic converter for my Chemistry finals at university. ( Lots of cool chemistry going on in an internal combustion engine and your cats that I have not mentioned and the cats do an amazing job at what they were designed to do in the 1970,s)
Perhaps I could expand on this and start a new thread if anyone is interested.
Best regards
Jerris
Best regards
Jerris
