anybody change the window regulator track???
Old Jan 27, 2006 | 08:03 PM
MY 95's Avatar
MY 95
CI 2-3-4-5-6-8-9 Veteran
St. Jude Donor '05-'06-'07-'08
Default anybody change the window regulator track???
looks like the track on the 85 broke so we have to re do it..........how hard is it???
Old Jan 27, 2006 | 08:25 PM
CFI-EFI's Avatar
CFI-EFI
I've never changed the track, but I have, the ribbon. I'm guessing it is a similar job. It isn't too bad. There were a couple of rivets I had to drill out, but I was able to replace them with screws and nuts.
RACE ON!!!
Old Jan 28, 2006 | 07:46 AM
MY 95's Avatar
MY 95
thanks
Old Jan 28, 2006 | 08:27 AM
MY 95's Avatar
MY 95
looks like the ribbon is whats bad......i just had mywords messed up
Old Jan 28, 2006 | 08:50 AM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
Now would be the perfect time to upgrade to the newer style regulator and get rid of those super slow ribbon types. There is a very detailed write up in the search section. I did my 85's and I like them a whole lot better. A little bit of simple measuring and drilling a couple holes on the bottom and the rest is bolt-in.
Old Jan 28, 2006 | 11:04 AM
MrRenoman's Avatar
MrRenoman
I'm pretty sure you're going to have to remove the regulator from the car anyway to replace the ribbon. If the motor is still good and you lube the ribbon and track it might last a good while longer. It's an inexpensive fix which will get you back on the road. It's just the slow window closing that finally got to me. I just upgraded to the newer style. You can do one side at a time. You can find them use for about $75-$100 on Ebay or find them in the for sale section once in awhile. You do have to drill a hole to two in the bottom of your door and reverse the wiring to the motor, but that's it. Huge difference in performance.
Art
Old Jan 28, 2006 | 11:09 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Not hard but time consuming.
Look in teck tips for a list of instructions.
You can buy the ribbon at AutoZone in the HELP section. Its listed for a Chrysler product but has the same general profile and is about 30 bucks less! I used this one and it has worked perfect for two years
To anybody change the window regulator track???
