Normal oil temp, pressure...
Old Jan 28, 2006 | 10:21 AM
lange's Avatar
lange
Default Normal oil temp, pressure...
Tried my new 86 for the first time yesterday. Oil and coolant temps was at about 200-208 after a 30 minute city drive.
Is this normal or a bit high?
What are the normal temps and pressure for oil and coolant.
thanks
Old Jan 28, 2006 | 10:26 AM
vader86's Avatar
vader86
Cold idle should be around 55-60, as should open throttle.
Hot idle can drop into the 20-30psi range.
your temps are normal
Old Jan 28, 2006 | 10:37 AM
rick lambert's Avatar
rick lambert
same here.
Old Jan 28, 2006 | 10:43 AM
lange's Avatar
lange
what's the critical temp, when I know there's a problem?
Old Jan 28, 2006 | 07:19 PM
Fuzzy Dice's Avatar
Fuzzy Dice
Cruise-In IV Veteran
If you ever hit 245 on coolant I'd shut her down...constant 250-260 on oil temp gets my attention...
Old Jan 28, 2006 | 09:03 PM
86PACER's Avatar
86PACER
A little red box will light up next to the temp/pressure reading.
Old Jan 28, 2006 | 09:36 PM
vader86's Avatar
vader86
250-260
To Normal oil temp, pressure...
