85 corvette with 3 problems...help
Old Feb 1, 2006 | 04:19 AM
steve1ph2's Avatar
steve1ph2
Originally Posted by MR NICE
Do you know how to spell correctly?Or is that some kind of internet lango?not meaning any disrespect cause I $uck at spelling myself.
mr nice, could you just be helpfull?
Old Feb 1, 2006 | 07:10 AM
mseven's Avatar
mseven
To the post here is an opinion for you,
Sounds alone make for inaccuarate assumptions. It is going to be hard for anyone to give an exact diagnosis. As knowledgeable as Pete K and CFI-EFI are you will have to give them more to go on, some visual inspections, and or, how someone else came to those conclusions (based on what methods they took to determine the problem).
"GRINDING" from rear: If you are bringing it to someone they need to show you why, and ask how they have diagnosed a bearing, brakes, rear end etc. (have them show you). The price of parts doing brakes is a lot different than bearing assembly.
"BACK FIRING" under load: problem is it can be many things, some simple some not, car would first need to have all the basics checked, spark (ignition system, wires, cap, rotor including timing), fuel (delivery system, pressure, filter etc), vacuum leaks, a scanner would help. You will need to pinpoint the problem so as not to just change parts and find you have not fixed the problem.
If you choose, buying a manual would help you to at least see the possible diagnosis and methods to resolving problems.
If the mechanic you have taken it to talked about replacing a trans. mount, find a new mechanic. JMO
Old Feb 1, 2006 | 07:56 AM
Pete K's Avatar
Pete K
Originally Posted by qws
Thanks pete k for clearing this up. Thought I was losing my mind for a min. You had mentioned in a post yesterday about where to find the number on the transmission in order to tell if it was produced early or not. Which side of the tranny is that plate on? I looked earlier and didn't see it.
The number is on the pass side, just above the pan rail, toward the rear of the rail. GM repacement units sometimes gring off the number, but you will see grinder marks quite clearly if this is the case.Shoot me the number and I will break it down.
Edit: I should not have made the post about the trans mount. It was a silly attempt to be funny. Did not mean to add confusion. Sorry.
Old Feb 1, 2006 | 04:59 PM
CFI-EFI's Avatar
CFI-EFI
Possibly, I was the only one that got it. Like I said, let me know if you start to run low.
I do get tired of admittedly, well intentioned people, spouting falsehoods, to people seeking help. If one isn't awfully sure of their facts, either they should state that up front, or keep quiet. Most questions are asked in search of guidance. False information can send someone off on a snipe hunt, wasting time and maybe money, for no good reason. [Down off of soap box]
RACE ON!!!
