Nasty ping...need advice
Old Aug 7, 2001 | 11:29 PM
Gordon Lee's Avatar
Gordon Lee
Cruising
Default Nasty ping...need advice
The other day my 95 LT-1 has started to ping badly during acceleration. The water temp hasn't been sitting at 190 degrees like normal it rambles around more now and seems to climb quickly with engine load. Never got over 220 yet, but the weather is just warming up this week.
I monitored the PCM with PCMcomm and it say the engine is knocking lots (thousands of counts per throttle stab), the timing is being retarded when this happens.
Any ideas will be appreciated.
Gordon
Old Aug 8, 2001 | 07:17 AM
L98Terror's Avatar
L98Terror
W. Detroit Events Coordinator
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VII Autocross Champ
Default Re: Nasty ping...need advice (Gordon Lee)
Check your fuel and maybe the knock senser
Old Aug 8, 2001 | 02:54 PM
GlockLT4's Avatar
GlockLT4
I had something similar.. but it wasn't pinging.. but missing. Turned out to be my opti-crap.. (the waterpump killed it)
Old Aug 8, 2001 | 04:03 PM
AquaMetallic94LT1's Avatar
AquaMetallic94LT1
You may have plugged catalytic converter or converters. It could also be a bad EGR valve.
To Nasty ping...need advice
