Cold Start Delete Ideas...
Old Feb 1, 2006 | 10:15 PM
ccmano's Avatar
ccmano
Default Cold Start Delete Ideas...
Don't want to spend $20 on a Cold start delete kit....anybody have any cheaper solutions...I'm installling a set of early model Accel runners on my 91'..
Old Feb 1, 2006 | 10:29 PM
-=Jeff=-'s Avatar
-=Jeff=-
$20 is a good deal for the kit, I thought it was $70.. I did it on a friends 88
Worth every penny
Old Feb 1, 2006 | 10:47 PM
Fork501's Avatar
Fork501
Hate to butt in, but I've never even seen one of these kits. Details on any for sale?
~Derek
Old Feb 1, 2006 | 11:40 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Do you have a chip that compensates for cold starts?
If so just pull the plug on the injector and see if the chip works.
Old Feb 1, 2006 | 11:47 PM
goldeneye_vet's Avatar
goldeneye_vet
~Derek
http://www.jimsperformance.com/carty2.html They also sell them on ebay from time to time. I have no experience with this vendor or the kit though.
Old Feb 2, 2006 | 12:33 AM
rodj's Avatar
rodj
You '91 has the start enrichment built in to the program so it doesn't need the injector.
If you don't want to shell out for the plug , have the hole welded up so it looks the same as the later runners.
Note for the others.
I have deleted the cold start on my '87 5 years ago , no starting problems.No mods to ECM program made.
Plug the runner and the fuel line, remove redundant parts.Possibly in severely cold places may need to have program modded to same as later non cold start.
Old Feb 2, 2006 | 10:41 AM
kopbet89c4's Avatar
kopbet89c4
Well, I used some JB Weld and a dime because my 89 had a pre-89 fuel rail, even if the CSI was there but not physically connected to the harness. This was during my SuperRam swap. Made the fuel rail worth 10 cents more.
Old Feb 2, 2006 | 09:16 PM
Mike_88Z51's Avatar
Mike_88Z51
From: Sacramento, CA Money can't buy happiness - but it's more comfortable to cry in a Corvette than a Yugo.
He is right, you should not even have a cold start injector mounting hole unless you have 88 or earlier runners. They did away with the cold start injector completely in 89 and adjusted the cold start enrichment values in the ECM to compensate. The 89+ L-98 runners do not have an opening for a cold start injector.
I agree. If you did have an 88 or 87 and wanted to eliminate the cold start injector circuit, usually you don't need to adjust the ECM tuning. If you live in a cold climate and are worried about really cold start conditions, it is my understanding that with the auto tranny cars you can swap an 89 auto chip in place of the earlier 88/87 chip since the auto trannies are so similar. You cannot do this for the manual tranny cars because the ECMs for pre-89 are programmed for the DN 4+3 manual tranny and the 89s have the 6-speed programming.
Old Feb 17, 2006 | 07:12 PM
ccmano's Avatar
ccmano
That's what I like about this forum....great ideas! Used JB Weld and a nickel. Worked like a charm....
To Cold Start Delete Ideas...
