cluch pedal
Old Feb 3, 2006 | 08:54 AM
ultra12's Avatar
ultra12
Default cluch pedal
hi i have changed the slave an master on a 85 4+3 . have to depress cluch pedal about 2-3in to floor to shift .fork good evething else good .did it come from factery like this .im 5:7 tall have to sit up on steering wheel any good idears out thier.other than costomizning cluch pedal
Old Feb 3, 2006 | 11:36 AM
byebyeL98's Avatar
byebyeL98
St. Jude Donor '10-'11-'12-'13
It sounds like you still have air in the system. What bleeding method did you use? The clutch hydraulics can be a real PITA to bleed sometimes.
I bought a Phoenix Injector tool for that purpose and I love it.
Old Feb 6, 2006 | 10:07 AM
ultra12's Avatar
ultra12
Default cluch
the instuctions in repair manual . like you said a pita ware do i get that tool
Old Feb 6, 2006 | 12:26 PM
byebyeL98's Avatar
byebyeL98
If I remember correctly, I got it from www.northerntool.com. You can visit the manufacturer's web site at www.phxsyss.com to get a full description.
They are not cheap, but worth it for me. Other guys have also had good luck with a Mity Vac tool.
Old Feb 8, 2006 | 08:38 AM
ultra12's Avatar
ultra12
Default cluch
i had the a guy that deals only with vets bleed the system .sayes thier nothing more that can be done thats just the way it works. somebody said that thier is a adjustment on cluch by fork cant find it in book or at cluch .slave comes out .pushes fork thats it 1985 4+3
Old Feb 8, 2006 | 09:44 AM
GRX's Avatar
GRX
Bleed with slave cylinder off bellhousing; with bleed nipple elevated uppermost; and insure slave piston is pushed ALL the way into slave cylinder.
Old Feb 8, 2006 | 01:02 PM
byebyeL98's Avatar
byebyeL98
If it is fully bled, and the system is functioning properly with the correct components, there aren't many other options for you. To my knowledge, there is no factory method of adjusting pedal height.
2" to 3" of clutch pedal movement before the beginning of clutch engagement is probably about right, but maybe some other members will chime in on this one.
Mcleod does make a larger bore master cylinder with an adjustable push rod. The larger bore will push more fluid, which will raise the point of engagement / disengagement. I am not suggesting this is the answer to your problem, just letting you know it's out there for consideration.
To cluch pedal
