Power Antenea cut out switch
Old Aug 8, 2001 | 10:54 AM
1986vert's Avatar
1986vert
Default Power Antenea cut out switch
I was installing a power antenea switch on a 1984 and according to the directions it goes in the pink wire coming out of the white connector block by the right door and it is marked C. I cut this wire and installed the switch and the antenea doesn't go up until you flip the switch. The radio also won't play anything, like tapes or even static until the switch is on, well this sorta defeats the purpose. Any ideas on how to make this work??
