Throttle Body Question
These are a few suggestions based on my limited knowledge.
Rich
Shorty headers are the only legal headers for your car. They will offer some improvement for you, but nothing like a long tube header will. But then you have to weigh the legal and smog factors....
LT4 intake will not only not work with your heads, but it will also offer no improvement over the LT1 intake. The LT1 intake is a great piece and can support 500 RWHP NA with a little cleanup. Don't mess with it.
The intake on your car is, for the most part, optimized with the cut stock air lid and K&N. The only real reason to go with any of the other pieces is style although a HP or two is possible.
Given that your car is a MAF car, you will more than likely not have to do anything for tuning. As long as your MAF is unported, it will report the amount of air comming in and the computer will accurately dispense fuel and such.
If you have an auto, your shift points MIGHT be changed a little and it is up to you if they are acceptable or not.
Good Luck,
