help!!!!
Old Feb 5, 2006 | 02:04 PM
curtismoff's Avatar
curtismoff
Default help!!!!
94 how do I reset oil change light?Why does my insisde lights stay on for 10-15 minutes it is very annoying at night.
Old Feb 5, 2006 | 03:25 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
1.Turn the key to the "ON" position, but don't start the engine.
2.Press the ENG MET button on the Trip Monitor and release it.
Then, within 5 seconds, press and release the ENG MET button
again
3.Within 5 seconds, of Step 2, press and hold the Range
(1990-1991) button or the Gauges (1992-1996) button on the
Trip Monitor. The CHANGE OIL light will flash.
4.Hold the RANGE or GAUGES button until the CHANGE OIL light
stops flashing and goes out. When the light goes out, the
ENGINE OIL LIFE is reset. This should take about 10 seconds.
If it doesn't reset, turn the ignition "OFF" and repeat the
procedure.
