Service Engine Soon Warning Light
thanks
When you have the trouble code, that will suggest what to look for first.
You need to purchase a Helms manual to fix problems. It can be purchased at www.helminc.com Good luck
Turn on ignition switch ( do not start)
Codes will flash on digital speedometer. ( have pen and paper ready to write them down). If you miss codes just turn ignition key off and back on.
H before number means history code in memory. C means current code.
Post the codes and I will look them up in my 1992 FSM and tell you what they mean.
You can also put paper clip between terminals A and B and count the flashes on the check engine light but the above gives you much more info with regards to history and current.
You can also reset the codes when bridgeing A and G without disconnecting your battery. There is also other information available in this mode that I can walk you through after you pull the codes.
Good luck
Jerris
If you do any work on your car it would benefit you to buy the HELMS Factory Service manual set as elefkow suggested. There are other diagnostics built into the car to help in troubleshooting
http://www.c4vettes.com/ecm.htm
Great pictures, followed by procedures to pull codes, and a list of codes and what they mean. And yes, getting the factory service manuals is a MUST if you're going to turn your own wrench. Good Luck.
Good luck
Jerris
Ignore the rest this is the best way to do it.Here is a link to Bogus's write that says the same thing
http://www.c4guru.com/articles/CCMCodePull.pdf
Can anyone comment on the intermittent stall & signal loss at PCM and PCM replacement?
thanks
If the O2 sensors were both bad, something caused then to go bad and you need to know what made them go bad or you will soon be replaceing them again.
The O2 sensors are only the messenger that tell you when there is a problem somewhere else that makes them read out of ramge, which caused the ECM to flash the service engine light.
Find out what the codes were and perhaps we can help you solve the problen that made them throw a code in the first place.
O2 sensors do go bad sometimes but at 19,000 miles they should not just go bad without something else causing them to do so.
And telling you now that you need to buy an ECM sounds like he thinks he has found a sucker and is getting ready to throw parts and your $$$$$$ at a problem that might not exist. From your post it sounds like your engine is running fine so there is nothing wrong with the ECM but he knows that just changing the O2 sensors is not cureing the cause of the check engine light and that you will soon be back with the light on again and he can soak you for a new ECM while he also charges you to fix the oroginal problem.
Be warned and armed with info. Ask him for the codes that he pulled as I explained in my previous post, or get ready to be a new vette sucker and give away laot of $$$$$$$$.
I guess you realise by now I hate "technitions" that take vette owners for a ride on their $$$.
Jerris.
PS Signal loss at ECM gives a particular code so unless you had one of these codes, they are full of S***. I have a 92 Factory Service Manual so post the codes and I will tell you what the FSM says they are and how to fix them.
Jerris
-- Eric
If you have not done it go to www.helminc.com and order your factory service manual.You won't regret it and if you do someone her will buy it in a sec.
13 is the left O2 sensor
64 is right O2 sensor lean
Are these what you have now or what you had?
64 does not necessarily mean it is bad just lean.Do you have Datamaster to do a scan on it?That is what I would do at this point to see real time what is going on.Go to ALDLcable.com for a cable they have a link to Datamaster for a free download.
What is Datamaster?
Bill
Besring in mind that it could possibly be the ECM I think it is advisable to eliminate any other sources first.
As they are both setting a code at the same time they are both experiencing the same conditions at the same time and that leeds me to suspect a problem in the fuel supply system causing a lean condition because a lean condition can move both O2 sensors out of range.
You really need a Tech 1 or datamaster scan to test if the voltage to the o2 sensor is between 350mV and 550mV. If it is not you have a faulty ECM, if it is within this range there are a number of things to gheck.
If you do not have a scanner you may want to assume it is within this range and do the following tests:
1. Make sure both pigtails are not touching the exhaust manifolds (unlikely as they are seperate circuits and both sensors set their code)
2. MAP sensor. A manifold absolute Preassure sensor that causes the the ECM to sense a higher than normal vacium, will cause the system to go lean and both O2 will throw a code. Discommect the MAP sensor and if the lean condition is gone (no more code) replace the MAP sensor.
3. Fuel Contamination from water in the gas tank or really old gas (you dont drive the car mucm so it could be either) can cause a lean condition.
4 Dirty fuel injectors will also cause a lean condition. Put some injector conditioner and new gas in the tank and put some miles on the car.
5 Low fuel preassure can also cause a lean condition. Hook up a guel guage and tape it to the windshield and watch it while you are putting some miles on.
5 AIS systen can cause a lean condition if the air pump is operating in close loop. Let the engine idle until it warms up and goes into closed loop and check to see if the air pump is pumping air into the exhaust by disconnecting the hose on the exhaust side of the selonoit that cuts off the air.
6 If there is an exhaust leak above the O2 sensor the exhaust can pull extra iar into the exhaust pipe and cause the O2 sensor to register a lean condition. (unlikely as this would only affect one sensor and both has codes) This is easy to check by reving the engine in idle and listening or feeling for exhaust escaping when you plip the throttle.
There is alot of things listed above that you can check without a scanner or taking it to a dealership for a scan. Check these and report back. Your problem may be connected to the fact that you or the previous owner didnt drive the car very much. Take the car out with a full tank of new gas and take it through its paces for some miles and see if it clears up, these cars like to be driven and driven hard occasionally.
By the way I did not get your PM yet.
Hope this helps, keep at it and you will be rewarded with the pride of having fixed the problem yourself, and report often so that we can narrow down the possibilities.
Jerris
www.aldlcable.com get a cable and datamaster download and hook it up to a laptop. It plugs into your ALDL plug under the dash on the drivers side.It logs pretty much everthing that goes on in your engine from the ECM.You will be able to diagnose if you engine is running lean or not.Once you get a log you can post it and we can tell you what is up.
I'm really sick of this problem. Last one lasted 1200 miles.
Yes you can, and you should.
Jerris
I think you get 20 free trials and then 10 dollars for the rest
