Check Engine Light?
Old Feb 9, 2006 | 11:25 AM
KBoltz's Avatar
KBoltz
Default Check Engine Light?
Ok,
Ever since I had the car in for a safety inspection, the check engine light comes on whenever I put gas in. As part of the test, they pressurize the cap.
As soon as the tank reaches half full, the light goes out and stays off.
Time for a new gas cap, or could it be something else?
Kenny
Old Feb 9, 2006 | 12:56 PM
rick lambert's Avatar
rick lambert
see u got a 96, always nice to know what year. anyway-don't know about 96, and it may indeed be the cap, but, I had my Focus in the dealership, and it seems alot of fuels according to a Ford memo
are causing similar problems with fuel guages, 02s etc caused by sulphur contaminated fuel-their memo recommended Chevron techron-
just thought I would throw it in-I was using Shell.
Old Feb 9, 2006 | 02:15 PM
ittlfly's Avatar
ittlfly
With the engine check light coming on, the PCM is setting a code. It might help to read it first to see what the computer doesn't like. IMHO
Old Feb 9, 2006 | 02:37 PM
KBoltz's Avatar
KBoltz
Default Reading codes
I don't have a code reader. I was reviewing the owner's manual, and it said that it could be contaminated fuel or a bad fuel cap.
I will run the fuel out of this tank, and if that does not clear it up, I will replace the cap. If that doesn't work, I will have to take it to the local Chevy dealer (gag) and have them read the codes.
Kenny
Old Feb 9, 2006 | 04:37 PM
rick lambert
First-get some Chevron Techron Plus Fuel System Cleaner in what gas you have left, then fill it up somewhere else-my suggestion would be a Chevron station.
Second-go to this site and learn how to read, diagnosis codes without
any special equipment-other than a paper clip!!!
http://www.c4vettes.com/ecm.htm
Good Luck
Old Feb 9, 2006 | 05:19 PM
Red Dwarf's Avatar
Red Dwarf
[QUOTE=rick lambert]First-get some Chevron Techron Plus Fuel System Cleaner in what gas you have left, then fill it up somewhere else-my suggestion would be a Chevron station.
Good Luck [/QUOTERick,
That site has changed to........http://www.corvettephotographs.com/c4vettes/index.htm
Old Feb 10, 2006 | 09:26 PM
KBoltz's Avatar
KBoltz
Default Thanks
Between the octane boost and the Chevron fuel system cleaner, the light went off within a few minutes.
No Chevron stations within 25 miles of me, so I will have to stick to the Exxon and no more Citgo gas.
Thanks for all the help,
Kenny
To Check Engine Light?
