Replacing Valve Gaskets
This is to give you a good idea of what to expect if you want to save some cash and do it yourself. It's not that difficult.. All you need are basic hand tools. I think it took me like 2 hours total taking my time.
Here is some pictures of my '86 for explenation purposes. I know the AC compressor is different on your '90. It does not get in the way of the early L98's to require it's removal. I don't know about yours though.
For the driver's side, the AIR pump (circled) is in the way. By simply loosening the lower braket bolts, you can slide the AIR Pump and alternator foward as one enough to clear the front lip of the valve cover, without removing them. Just slip off the serpetine belt from the AIR pump and alternator only. The fuel injector wiring harness can tend to get in the way too. You can just unplug it's wires leading to the sensors at the front and the fuel injectors, and swing the whole harness up and back towards the windshield. Remove that hard vaccum line under the injector harness.You just need to fish out the rear end of the valve cover from under the wiper motor to get it out. The brake booster line might give you a little trouble. That's about it for this side.
For the passanger side, the main thing in the way is the EGR pipe (Red arrow). Unbolt it from the exhaust and the intake manifold (torx bolts here). Remove one end of that rubber coolant line next to it and swing it out of the way. It also helps to unplug that injector harness, retreive the connectors, and swing the whole thing up and back for more room. The valve cover is clear for removal.
That's really it for mine. If I left anything out, someone please correct me. I've had mine off several times, and that's really all I did. I'm just going off memory here.
This would be a good time to replace egr or outer wrap if needed. Check all plug wires if on original looms ones in back of covers may be burned. Inspect PCV and hoses, etc.
The most time will be the learning curve and for the money this is a fairly easy DIY job. Take your time if you need a manual buy a helms not a chilton or whatever, pick a day where it does not need to be done fast, the first time will probably take at least a few of hours.
To mseven, where can I get some EGR wrap? Will local parts places have egr gaskets and/or wraps? Also, what's pb blaster, a rust cleaner?
Summit sells it by the foot and it is sewn like stock in different sizes. Mid america, ecklers etc. also sell the same (pre-cut) for EGR. PB Blaster is probably the best rust penetrating oil (sray can), most auto stores carry it murray's auto zone, etc.
Come to think of it, I do remember trying to take off the valve covers about a year ago and remember removing side components, but the alternator bolts gave me trouble from the last moron using some type of screw glue on it for whatever reason, so I had my mechanic loosen it for something else anyway, but forgot about the valve covers being removed at the time.
What probably happened is it wasn't secured tight enough or the seal was disturbed in some way causing he leak, so yeah they probably were just loose. It warns of this on the new seals(gaskets) I just bought. I'm gonna install new ones since I've got em anyway. It warns of a specific OEM torque setting on the covers once the gaskets are installed.....It says overtorquing it could screw up the effectiveness of the gasket. How tight should they be?
Also, checked Checker and Autozone and neither of them claim to have any EGR gaskets for a '90 vette. Checked with a GM Motorsports performance shop and they still told me they didn't carry them which is some wierd sh**. The valve cov gaskets I got but from what they're telling me around town I'm guessing the only place to carry the EGR gaskets would be a local GM dealer at a Chevy dealership? Lucky me, I just got there at closing time to even ask them. I was told the parts dept wont be open 'til Monday.
Thanks man. I'll try it out.
Other than that nothing hard about it .Local auto parts store should carry gaskets.
and get a really strong torx bit or one with a lifetime warranty i twisted and broke mine off in the bolt
. i got the thick metal reinforced rubber gaskets autozone had and no problems since except now my oil cap leaks
btw not a hard job and it's a good time to clean them up real well
:1/2" DRIVE long handle ratchet or 1/2" breaker bar costs the same or less, and can be used it for alot more than just a belt.
