supercharger question 87 Vette
Old Feb 10, 2006 | 03:27 AM
ratortor's Avatar
ratortor
Default supercharger question 87 Vette
Does anyone know what other mods are needed if I put a 6lb boost unit (Powerdyne) on my Corvette which has 30K miles and is in perfect running order.
It already has headers, chip,other bolt ons but original block.
It will not be used for regular racing at the track.
I want to make it as bulletproof as possible since I use it weekly.
Old Feb 11, 2006 | 02:14 AM
Mo_Bandy's Avatar
Mo_Bandy
As long as you have your fuel timing and knock retard under control you should be fine..
The pistons are always a risk, I'd invest in some logging software to be sure you have everything in order under boost...
Mo
Old Feb 11, 2006 | 02:01 PM
MrNuke's Avatar
MrNuke
You'll have to either get a custom programmed chip or put the stock one back in for the supercharger.. And of course do the normal stuff like lowering timing, add fuel if needed, etc.. etc...
Old Feb 12, 2006 | 10:46 AM
jadedvette's Avatar
jadedvette
The place you want to talk to is Supernatural-Performance. They sell the whole kit or parts. I'm talking to them now about installing one on my 86'.
Good luck,
Joe
Old Feb 12, 2006 | 10:55 AM
AKS Racing's Avatar
AKS Racing
Or you could buy a complete ATI kit that will deliver 12 psi and was built for the '87 and be worlds ahead of the Powerdyne. This kit includes an IC, FMU, and high psi fuel pump all for $3500.
Aaron
Old Feb 14, 2006 | 08:05 PM
ratortor's Avatar
ratortor
Default going with Powerdyne
Ill be going with the Powerdyne kit.
I'm looking for a mild setup and the Powerdyne unit
at 6lbs of boost and being self contained should suit me fine, not to mention that the kit contains the mechanicals and specifics for the Corvette.
The only thing I'm hoping is that the Supernatural people are reliable.
I'm pretty nervous paying that amount to a group that does not give out it's phone number or address (all email as far as I can see).
Comments?
Old Feb 15, 2006 | 02:36 PM
blown87's Avatar
blown87
GA Events Coordinator
Comments?
i think i would be nervous also, No phone, # no address, no $!
To supercharger question 87 Vette
