Correct Heated o2 Sensor for an 86?
Old Feb 10, 2006 | 12:07 PM
geezel's Avatar
geezel
Default Correct Heated o2 Sensor for an 86?
Looking for the correct 3-wire Bosch o2 sensor for my 86. I know the 13190 is the correct 3-wire for the 88-93's. The stock sensor is is different for the 84-87's so I'm thinking I need a different heated sensor. Thanks.
Old Feb 10, 2006 | 12:48 PM
-js-'s Avatar
-js-
You will need to add a circuit that will provide the power for the heater. You would also want the mating connector for whatever 3 wire O2 you use to make replacement easier.
You would want to do this mod if you have added long tube headers.
Old Feb 10, 2006 | 01:06 PM
Slalom4me's Avatar
Slalom4me
News to me, my '89 came with a single wire.
Here are a couple of links that may be useful. I wish I'd known about
the first one before I sourced/built my conversion. The second link
shows one way of tapping into a switched 12VDC source for the O2
heater.
Heater O2 sensor: Modify Aux Fan Relay for a switched 12VDC source
There are some tech tips and many other threads on the subject.
Old Feb 10, 2006 | 01:14 PM
geezel's Avatar
geezel
I'm going heated because of the headers.
Old Feb 10, 2006 | 02:02 PM
vader86's Avatar
vader86
You can use 13190
Old Feb 11, 2006 | 09:28 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Sensor is part number 25312179 - ACDELCO AFS74
Connector is part number 12126012 - ACDELCO PT643
I got the O2 on ebay for $28 and the weatherpack pigtail from my jobber for $9.
Old Feb 11, 2006 | 10:08 AM
comp's Avatar
comp
To Correct Heated o2 Sensor for an 86?
