Which hydraulic roller lifters do you recommend?
Old Feb 10, 2006 | 02:25 PM
tequilaboy's Avatar
tequilaboy
Default Which hydraulic roller lifters do you recommend?
If you've seen my other posts, it looks like I will be needing new lifters. I've seen some negative posts regarding comp R's. Any positive suggesions? Car is an 88 L98, with Comp 224/230 cam. I see comp 850-16 and crane for under $200, Comp 875-16, and GMPP for around $240. Oem around $100. Any thoughts from the forum?
Old Feb 10, 2006 | 02:31 PM
Zix's Avatar
Zix
The GMPP LT4 lifters are extremely good...I would run those if it was my decision
Old Feb 10, 2006 | 02:35 PM
STL94LT1's Avatar
STL94LT1
Two of my friends have had Comp R failures. I'm running the GMPP's,
FYI: I paid $203 for the GMPP's.
-Mike
Old Feb 10, 2006 | 04:36 PM
tequilaboy's Avatar
tequilaboy
Thanks for the replys, some positive feedback for the GMPP!
I'm currently leaning towards the Comp 850-16s I see for $178 shipped with a free Comp t-shirt.
Since I'm in Michigan, I've got some time to think it over before vette season begins around May.
I guess I have to step up my search for an accel base, now that I'll be pulling the intake soon...
Old Feb 10, 2006 | 06:42 PM
d48mclain's Avatar
d48mclain
Unless your cranking a bunch of rpm, lifers really aren't much of an issue as most all of them will work.
Comp R's will work great but must be set just right and there is some debate over olders ones being better than new ones. Morrell right now is considered the primo lifter.
Did a dyno test on Morrell vs. Comps and up to 7200 rpm there was no difference in power. Decided to use the Morrells.
Now springs.... that's another subject all together different.
Old Feb 10, 2006 | 11:54 PM
Red Tornado's Avatar
Red Tornado
I purchased mine via LPE, as I was purchasing a couple other items at the same time. The brand is Melling.
Old Feb 11, 2006 | 12:19 AM
cv67's Avatar
cv67
St. Jude Donor '05
Plain old stock type
Old Feb 11, 2006 | 02:51 AM
REDC4CORVETTE's Avatar
REDC4CORVETTE
Morrell gets a vote from me!
CompCams lifters suck!!!
Their excuse to me was you have to fire up the motor within 6 mths or the lifters rust?
Hu What?your lifters have a shelf life of 6 mths?
At least they sent me new ones,at no charge.
Old Feb 11, 2006 | 03:40 AM
tjwong's Avatar
tjwong
OE style roller lifters would work fine in your car. I don't recommend using the Comp 875-16 which are the Comp R lifters. There are race lifters and they need attention from time to time. Most of the failures that you hear about is due to mis-adjustment of the preload on these lifters. They are finicky to say that least and careful preloading is mandated. Otherwise failures can and will result. I have them running in three engines, my personal engine has had them for years without any issues.
Old Feb 11, 2006 | 04:32 AM
comp's Avatar
comp
thats BS
Old Feb 11, 2006 | 08:06 AM
mseven's Avatar
mseven
Since you live here you might want to check out a co. called DFI EFI (located in Mt. clemens or clinton twp.)they advertise on ebay and have had some of the best prices in the accell bases, SR.'s etc.
Morrells, if I remember were pretty pricey, definitely nice product.
If the weather here keeeps this up we may be getting spring weather sooner than usual
Old Feb 11, 2006 | 11:02 AM
LT4POWR's Avatar
LT4POWR
and Comp Rs or Morels aren't needed in this application. Go w/ OE replacements and you'll be fine.
Old Feb 11, 2006 | 11:21 AM
tjwong's Avatar
tjwong
I can beat their prices easily
Old Feb 11, 2006 | 12:03 PM
Slalom4me's Avatar
Slalom4me
When considering hydraulic rollers, another factor is their leakdown
rate. Matching lifters that leak down more rapidly can help retain
low RPM performance with a cam that might otherwise lack sufficent
manners. This approach can even be used to tune for different I/E
behavior by running differing leakdown rates on intakes/exhausts.
Vizard's How to Build & Modify Chevrolet S-B V-8 Camshafts & V-trains
(ISBN 0-87938-595-2) includes a lengthy, in-depth look at leak-down.
The flip-side is that if you mismatch lifters and cam, you leave performance
on the table.
Old Feb 11, 2006 | 12:54 PM
pr0zac's Avatar
pr0zac
comp lifters suck a butt.. don't waste your money.. GMPP or Melling
Old Feb 12, 2006 | 11:54 AM
d48mclain's Avatar
d48mclain
on the table.
I'm probably wasting a bunch of money on the Morells but for sure springs can effect hp production and so can how you set the lash.
As mentioned we did dyno Comp R's and Morells and didn't pick up any difference if each is setup to how they like to be setup. In general a looser lash makes more power but the problem with Comps is.....yes they are very fickle and you need to find of the combination of preload. Too little and they break, too much you loose power. The Morels on the other hand like a little more preload.
Springs make a huge difference. As much as 20-30 hp on top between springs on an engine reving pretty high.
Below 6000 rpm I not so sure there are a whole lot fo differences in lifters or springs that are of a certain quality level and match the combo.
Old Feb 12, 2006 | 06:20 PM
REDC4CORVETTE
Originally Posted by comp
thats BS
Talk to RED at comp cams ,He replaced them.
No BS their.
They would not pump up and 4 the roller did not even move.
He said it was the coating they were using.
To Which hydraulic roller lifters do you recommend?
Old Feb 12, 2006 | 08:35 PM
Gold1986Vette420's Avatar
Gold1986Vette420
If you choose Comp roller lifters be sure they peened the heads of the bolts that retain the t-bar. one bolt on mine came loose and the tbar came off causing the lifter to rotate and wiped the cam and then metal fragments wiped my motor. *solid roller cam. That was at 800 miles. $6500 later its up and running, and I had my guy at the machine shop repeen the new ones just in case.
Old Feb 12, 2006 | 08:42 PM
VenkmanP's Avatar
VenkmanP
http://web.camaross.com/forums/showthread.php?t=394574
Old Feb 13, 2006 | 05:42 AM
93 ragtop's Avatar
93 ragtop
on the table.
Have you considered the Rhodes lifters? I have no experience with them but I believe the principle behind them is to do what you are suggesting above.
