396...itīs alive!!!!
maybe some of you know me building a 396..
today i fired her up...a bit tweaking with ignition timing..and it runs...
what a sound!!! it sounds very torquey! also, the McLeod Stree Twin releases fine!!
i want to say many thanks to all that helped me, answered questions, aso...
special thanks to Jake, cuisinartvet, CorvetteKidNc, Steve40th, Mos90, LD85, Slalom4me, luvmy92,FD2BLK,mothersworry, and all the others
i have a bit problems with high oil pressure, since i used a high volume pump, but all in all..it runs
also thanks to Alvin for the tune, i hope i can drive soon, to have it refined.
have a nice day
Reinhold aka Corvette90
Congrats, and on the high oil presure, is it sticking at 80 PSI? If so it may just be a bad sensor or a poor ground. I had a problem on my 84 when i droped in the LT1 where a bad ground caused my OP to read much higer then it actualy was. The bad ground would cause it to read about 65 PSI hot at idle and if you even touched the throttle to jump to 80.
I put mine in over Christmas...
If you want to take a look http://www.ndneyes.com/mo/projects1.html
Good luck with your tune
Mo
sounds a bit familiar...
the pressure stays at about 60 psi, goes up when i give gas slowly, and suddenly jumps to over the board!
i will take a closer look at the sender!!
thanks for the suggestion!!!
Mo
Hi Mo
thank you!!
i know your site very well, i came across it, when i searched google for 396..
looks very nice and clean your engine!!
have you fired it up already?
regards
A qick check that worked for me is to find a good place on the sender with no paint (I Scaped it a little to mak sure) Then I used a hose clamp to clamp a wire to the outside of the sender and hooked the other end to a known good ground (I used an intake stud). For me the problem wqs that I had remote mounted my sending unit with rubber line but I could see the exact same problem with teflon tape or RTV if it became an insilator. The sending unit needs ground as a refence. I hope this helps if not it was a free shot.
Mo
i used an GMPP Block, so clearancing was moddest, i think about .1-.15 inches
i used an forged eagle crank, and a 240-15T (hope this is the correct number) stroker oil pan from Canton.
i had only to bend the crank scraper about .050 inches
the sound...a deep rumble, with a bit lope..just fine :-) ..big block style
Ths street twin should take the abuse..i hope so
There are a few things that effect oil pressure other than bearing clearances. One is the weight of the oil you're using and another is the temperature of the oil.
Once the oil reaches normal operating temperature, somewhere in the area of 200 degrees F, the pressure will be lower than it is when the oil is cold as when the engine is first started.
The ambient temperature - how cold it is in the garage or outside - will cause the oil to take longer to reach its operating temperature, so go easy on the RPMs until the oil comes up to normal temperature.
Keep us posted on what you find.
Jake
regards, all...
Mo
i use 10W-30 oil, maybe i will switch to Mobil 1, also, i wont be hard at the throttle for the first 1000 miles
How would you break in the engine?
i read somewhere, ot to make the highest rpm, but put load on the engine..that expands the rings against the walls and seat them well
thank you
Here is the i followed and by others on here.
Congrats on new killer, post some idle and rev vedio clips, i love that muscle sound.
People are just leary the first couple of times running a motor real hard, as that is usually when you find something is not right.
As for the rings, I always just run the car like normal - HARD.
They are like kids, teach them early what you expect and the rest is pretty simple.
This method worked great for me every time! You can pretty much break it in, in the first 30 minutes of driving the car once it is warmed up!
Hope this helps
Jerris
