Snapped a rear spline
Old Aug 9, 2001 | 07:44 PM
TurboVette's Avatar
TurboVette
Default Snapped a rear spline
Broke it clean in two and it looks like the other side was going to break soon. It was on the passenger side in my 85 C4. GM doesn't carry them any more, so I had to put in a couple of used ones. I've beefed up the rest of the driveline, but I think this will remain the weakest link. Are there any after-market heavy duty or billet splines available?
Old Aug 9, 2001 | 07:57 PM
bill mcdonald's Avatar
bill mcdonald
Default Re: Snapped a rear spline (TurboVette)
nice work! I asume this happened durring a hard launch?
http://www.tomsdifferentials.com/
Check with them to see.
Old Aug 9, 2001 | 09:50 PM
TurboVette's Avatar
TurboVette
Default Re: Snapped a rear spline (bill mcdonald)
Yes, it broke at the line, but the pass before that one was a rush!
Thanks, I'll call them tomorrow.
Old Aug 10, 2001 | 04:22 AM
bill mcdonald
Let me know if they have the parts you need.
Also, with your turbo mounted where it is, is there any problems with heat and the fiberglass hood?
Old Aug 10, 2001 | 11:49 AM
Ruby6spd's Avatar
Ruby6spd
Active Streak: 90 Days
toms differential has the outer and inner axle's that are cold stabilized.. I picked up all of them a couple of weeks back and will be installing when i get the rear this weekend...
beware-- they are not cheap----but with your turbo they would probably be worth it...
Old Aug 11, 2001 | 03:04 AM
TurboVette's Avatar
TurboVette
Thanks, Bill.
I called Tom's today and he did not have a replacement piece that was stronger, but would like to make one if there were enough people that wanted it. I wonder if others here need a stronger one. I'm going to try Tom's cold stabilized spindle but, I'll wait until I break these new ones first.
I was worried about the turbo's placement also. It glows red-hot after beating on it for a while, but it seems to be fine.
Old Aug 12, 2001 | 01:56 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
I am not following "I called Tom's today and he did not have a replacement piece that was stronger, but would like to make one if there were enough people that wanted it. I wonder if others here need a stronger one. I'm going to try Tom's cold stabilized spindle but, I'll wait until I break these new ones first."
It reads to me that he did not have a stronger peice, but you bought the stronger peice. I am lost. Are you refering to the half shafts? I know he does not have any stronger replacements for those.
I run the treated spindles from Tom's and it is a stronger peice. Think about getting his cold forged Spicer u-joints too depending on what brand you are currently using.
Old Aug 12, 2001 | 06:58 PM
TurboVette's Avatar
TurboVette
Default Re: Snapped a rear spline (Vette92)
Tom's felt the "cold stabilized" spindle that he could offer was not the right answer for the car and that it was possible I could break that one also. The stronger one he was referring to was a new machined piece that he would need to make from scratch, but the cost was prohibitive for just a couple of sets.
To get the car back on the road, I put in used stock spindles for the time being but if (when) I snap these ones, I try the "cold stabilized" pieces even though they are not the ultimate answer.
I already have Spicer U-joints (the big brutes work well also) and heavy-duty half shafts.
To Snapped a rear spline
