[Poll] How do you torque?
Aug 9, 2001 | 09:39 PM
:confused:
Aug 9, 2001 | 09:49 PM
Re: [Poll] How do you torque? (NoWorries)
Depending on how strong I feel that day I, 1. Tighten until I see juice coming out of the bolt, or 2. Tighten as tight as I can get it, then two more turns.
Aug 9, 2001 | 09:50 PM
Re: [Poll] How do you torque? (jfb)
tight is tight. i know my strength :yesnod:
Aug 9, 2001 | 10:40 PM
CI 3-4-5-6-7-8-9-10 Veteran
Always use the torque wrench. Drilling and easy outing broken bolts is not the way to spend the afternoon. :smash:
Aug 9, 2001 | 11:22 PM
I use a One Inch air impact gun to snug my bolts in. When the gun stops turning, then it's tight enough for me.
Aug 10, 2001 | 12:25 PM
Georgia Method - Tighten 'till it strips then back off 1/4 turn.
Aug 10, 2001 | 02:03 PM
Cruise-In II Veteran
Re: [Poll] How do you torque? (olephart)
hahaha, tighten till it strips and back off a 1/4 turn. thats :lol:
Aug 10, 2001 | 05:17 PM
Anything that is being attached to the engine i.e: water pump, heads, exhaust and intake mainfolds gets torqued. Stuff thats just screws and bolts get put on until there elbow torqued.
Aug 10, 2001 | 05:41 PM
Pre aluminum engine components I used to feel good about the elbow torque wrench,but, now a torque wrench and the correct specs are essential. I do miss the Georgia method however! :cheers:
Aug 10, 2001 | 06:21 PM
Re: [Poll] How do you torque? (JIM FL)
I use the torque wrench when the manual calls for a specific torque. I learned a long time ago, tight is tight, too tight is broke.
Aug 10, 2001 | 08:40 PM
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
I sleep with mine :D
Aug 10, 2001 | 09:32 PM
Torque wrench when it's called for in the manual, unless it's like 3 inch/pounds. :D Then I just give it a little twist and whack it. :smash:
Aug 11, 2001 | 03:44 AM
Impact wrench----------Ingersoll-Rand---------------Snap-on---------
-----------------------------ft/lbs--------------------ft/lbs----------
Rat a tat-------------------20-------------------------30
Rat a tat tat---------------30-------------------------40
Rat a tat tat rat------------40-------------------------50
Rat a tat tat rat a tat-------50------------------------ 60
jimilane
[Modified by Jimi Lane, 7:26 PM 8/11/2001]
