Code H32 on a 94
Old Feb 15, 2006 | 12:27 AM
Casethecorvetteman's Avatar
Casethecorvetteman
Default Code H32 on a 94
I was out for a drive last night and just cruising along when the Service Engine Soon light came on, the car was still running exactly the same, i checked for the code today, and it is H32, with the small number underneath that being 4. That was the only code that was there, and when i stopped the car and restarted it, the SES light didnt come back on. Can anyone tell me what this code means? The car is a 94 coupe. Thanks for your help in advance
Old Feb 16, 2006 | 07:08 AM
Casethecorvetteman
does anyone know??
Old Feb 22, 2006 | 06:58 PM
91vetteboy's Avatar
91vetteboy
Its a history code..32=EGR circuit fault.Not a current code.Try clearing the code.
Clear code by disconnecting battery or with ignition off,ground A to G on CCM(with paper clip) and turn ignition to "on" position. Don't start car.
Let any codes cycle on the LCD
Then press TRIP/ODO button till 1.7 apears in the trip monitor.
Then press ENG/MET button and hold until ---- appears in the speedometer area. This will clear the CCM codes
Turn ignition off
Turn ignition back on(Don't start car) and verify codes have cleared.
Once cleared, remove ground from A to G. Thats it.
Old Feb 22, 2006 | 07:35 PM
jabez's Avatar
jabez
I would worry more if it said C32
To Code H32 on a 94
