93 Cutting Out Intermintantly
Old Feb 15, 2006 | 06:58 PM
HOWSER's Avatar
HOWSER
St. Jude Donor '09
Default 93 Cutting Out Intermintantly
My 93 has started cutting out, at an increasing occurrence, this week. It will be running fine and then all of a sudden it's like someone just twisted the distributor a quarter turn.
I thought at first it could be bad gas. I had filled up Monday and that's when the first symptom started. It was more of a severe and sudden hesitation that day. I have ran most of the tank down and added both new gas (from a different station) and some Heat. Still the problem persists.
The opti was replaced about 3 years ago (around 15, 000 miles) as was the fuel filter. Someone mentioned to me that this was a symptom of a failing fuel pump. Is it?
I have yet to get under the hood. Any suggestions of where to start?
Eric
Old Feb 15, 2006 | 07:27 PM
ittlfly's Avatar
ittlfly
If it isn't throwing code(s)...I'd put a fuel pressure guage on the schrader, tape it to the windshield and go for a ride. When it cuts out and the fp remains steady, then its probably ign.......if the pressure drops, then trouble shoot the fuel system.
Old Feb 15, 2006 | 08:01 PM
plumberh2o's Avatar
plumberh2o
Old Feb 16, 2006 | 09:06 AM
HOWSER's Avatar
HOWSER
St. Jude Donor '09
Thanks. Anybody else have any suggestions?
Old Feb 16, 2006 | 10:52 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Couldn't hurt to inspect your coil and wires, too. They might be experiencing intermittment arcing...
Old Feb 16, 2006 | 11:03 AM
SJW's Avatar
SJW
When it misbehaves, does it misfire and/or backfire, or just act as though the fuel supply vanished?
Break the problem in half first. Determine whether it's a fuel supply problem, or an ignition problem, and then go after the trouble from there.
As others have noted, a fuel pressure test while the car is misbehaving will tell you a lot, and that's probably where I'd start.
Be well,
SJW
Old Feb 16, 2006 | 07:59 PM
HOWSER's Avatar
HOWSER
St. Jude Donor '09
Well today it completely pooped out on me on the highway. I have yet to test the fuel pressure but I have a good idea that it may be ok. It acts like it's getting no spark at all. I can smell gas when trying to start it.
I'll try to test the fuel pressure this weekend. I'll keep you guys posted.
Thank you!
Old Feb 16, 2006 | 08:45 PM
Jerris's Avatar
Jerris
Check your ICM and connections to it. It sounds like a spark problem.
Jerris
To 93 Cutting Out Intermintantly
