Can Motor Oil Catch Fire?
Old Feb 16, 2006 | 08:15 AM
CG77VETTE's Avatar
CG77VETTE
Default Can Motor Oil Catch Fire?
I'm asking since my valve covers just started leaking oil onto the exhaust manifold. I will be replacing the gaskets in the Spring but I don't want to run the risk of a fire while running the engine until I get to the repair. Thanks for any help.
Old Feb 16, 2006 | 08:30 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Lubricating oil, such as motor oil, is not volatile but it is combustible.
It must be heated to over 400 F in order to burn. Thus, for lubricating oil to catch fire, some other intense source of heat must be present such as other materials on fire, engine manifolds, an over-heating bearing and the like.
Old Feb 16, 2006 | 08:42 AM
thomastl's Avatar
thomastl
Yes, it can burn if it gets on the exhaust.
Here is a link to a temp chart for flash point. Actual sustained burn point is slightly higher but flash point is when you will get an ignition.
It indicates that Mobil 1 5w30 is at 445 degrees.
http://www.micapeak.com/info/oiled.html
Most exhaust manifolds run in excess of 1000 degrees.
If it is a bad leak - fix it now.
Old Feb 16, 2006 | 11:24 AM
rklessdriver's Avatar
rklessdriver
Yes it can burn, but it takes a lot of heat. I mean a lot of heat, just from experience my old 89 Jeep Cherokee has about 270,000 miles on it (I only use it as a winter beater/mud bogger in the summer) and blows oil out every where, I haven't caught it on fire... yet. If your ride is leaking as bad as my Jeep I don't recommend you try to find the flash point.
Will
Old Feb 16, 2006 | 12:47 PM
CG77VETTE's Avatar
CG77VETTE
Thanks for all the input. I guess it's "off with the valve covers" this weekend!
To Can Motor Oil Catch Fire?
