Corner Weight Balancing?
Old Aug 10, 2001 | 01:32 PM
Zpeedstr's Avatar
Zpeedstr
Default Corner Weight Balancing?
I'm trying to balance the corner weights on my '96,
which seems to be impossible with the monospring.
The starting weights with driver (170 lbs) are:
LF-989, RF-889, LR-826, RR-746.
This is with the ride height at the preferred setting.
Now I can jack the weight around with the perch adjusters,
(the VetteBrake's front spring has adjusters, as well as the stock rear bolt)
but then the ride height is wrong.
I have thought of getting adjustable sway bar ends and using them for weight jacking,
but that might make for some other problems with handling.
So --- is there some other method of adding spring stiffness to just one side?
Rik
