Key stuck in column
Old Feb 18, 2006 | 07:48 PM
JA94vette's Avatar
JA94vette
Default Key stuck in column
Well this week is kicking my vette's butt. The tranny is on it way out and I just ordered a clutch and parts for a 4L60E to ZF6 conversion to do next week.
I drove it today to bring a friend to work and I went to shut the car off and the key was stuck in the on position. I hit the starter on accident and it finally came unstuck.
I cranked it again and it was stuck but even weirder, the AC and radio would not come . All my guages worked except for mpg, it kept changing from 0 to 5y5 the whole time. Also, none of the buttons for the guages (guage/eng met/trip od/trip fuel) worked. I got back home and tried to take the key out but no good. I had to kill the car a different way and the key is suck in the ignition.
Any ideas???
Old Feb 18, 2006 | 08:57 PM
The Green Hornet's Avatar
The Green Hornet
From: Everyone needs something to believe in, I believe I'll have another beer. Wisconsin
Same thing happened to my c3, dicked around for 30min. with it, finally
used a pliers to shut it off. Pull the steering wheel and replace the ignition lock and key.
Old Feb 18, 2006 | 11:09 PM
JA94vette's Avatar
JA94vette
Yeah..i know i'm going to have to replace the key. Is that the only problem you think i have??? I'm more worried about the ectrical part. Is this the right part and since i'm swapping in a manual...would part number D1453C on this webpage fit in my A4 column???
http://www.rockauto.com/catalog/cata...&parttype=4516
Old Feb 19, 2006 | 10:53 AM
jabez's Avatar
jabez
Once in a while my key gets stuck in the ignition. I just jiggle the shifter and the key would come out.
Old Feb 19, 2006 | 11:17 AM
The Green Hornet
My guess would be yes, that would be it. if the key is stuck and you
can't turn it without forceing it the cylinder assy.needs to be replaced
Old Feb 19, 2006 | 12:20 PM
hippy's Avatar
hippy
Try getting some Dry Graphite Lubricant in there. Your tumblers are probably stuck. That stuff works wonders. My 89 had a sticky set of tumblers where I couldn't the key out, I shot that stuff in and no more problems.
Old Feb 19, 2006 | 03:54 PM
JA94vette's Avatar
JA94vette
That's what i'll do thanks for the help...I hope all of this is related and the switch is just making a bad contact. I'm really worried about why the AC/radio/guages won't work.
Old Feb 20, 2006 | 03:48 PM
parafrog's Avatar
parafrog
From: Tucson, AZ. L98-85 AUTO COUPE: 120k MILES: daily driver. SOUND OFF IF YOU'VE BEEN THERE. Ex-Jumpin' Junky-82nd Airborne-2/505 PIR: 1st ID-1/16th Inf: Recon Marine Retread. GOD BLESS GRUNTS.
try this tip for the stuck lock.
http://www.gmtips.com/3rd-degree/dox/tips/misc/key.htm
froggy..
To Key stuck in column
