I'v been looking at the csr waterpump for some time now for my lt1. Only $150 at summit. I have an electric waterpump from csr on another gen 1 small block that I built. Its a real nice peace.
Me too. Where this mod pays off is if you have an aftermarket cam and you wish (wisely) to upgrade your timing chain set, the use of the electric pump allows you to use basically whatever chain set you want (ie for the small block Chevy, double roller if desired) instead of using GM's LT4 or LT4 Extreme duty sets. These sets, in my humble opinion and personal experience, are not very good quality.
In about a month I will be taking my motor out and looking at My ED timing chain. I really want to to see if its got any wear marks etc. I installed it correctly, and there is no noise after maybe 1000 miles (not much I know).
And then I am going to remove the water pump gear portion, and use the ED chain etc, and put in a Miezre.
The Miezre has a larger motor and better seal. This data I gathered after researching the same issue of going to a Electric water pump.
I've had my Meziere HD for almost 5 years now, no complaints! The main thing is to get a good relay, I went through 3 relays. I also upgraded to a Cloyes double roller with my last engine build since I eliminated the stock waterpump drive.
I thoght electric water pumps were track only type stuff? Now its been a long time since I read anything about them (7 or 8 years) but last I heard they overheated like crazy and frequently failed? I guess this has changed? Can they stand up to everyday abuse now?
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Many of them still are. That's why you've got to know what you're buying.
And also a good relay connector. I thought I bought a good one, it was a Borg-Warner, looked well made with heavy enough wire leads, etc. But I was popping relays every few hundred miles at first and I know I was using good relays. So I finally built my own connector and installed a new NAPA relay and have had no problems for many thousands of miles since.
Chris, what relay and relay connector did you end up with?
I know you didn't ask me, but FYI I used a GM weatherpack relay and GM weatherpack connectors. You don't want corrosion and you can get it in an engine bay environment. Others might work but if you look at the other connectors in your engine bay, they are all weatherpack, I gather to prevent corrosion.
Hi Steve--nice to see you're back!!
Yeah--1000 mi I don't think will tell you anything. I still suspect just a bad mechanical waterpump in conjunction with a very marginal gear (hardness is marginal--ok perhaps if the pump bearing is perfectly smooth).
What would tell us something is the hardness in the tooth area of a 60,000 mi ED gear or if we all have bad waterpumps. Mine is completely seized now, and sometime I have to have it pulled apart to see what's in there.
Hey Good to be back, I will go with the Meizere. And, I will take pictures etc of when it, Timing gears and chain, and study the gears for wear issues.
From: 1984 crossfire, Alhaurin de la Torre Malaga, Spain
Originally Posted by 96 lt-4
thanks for the replies.i guess i will wait until i have to replace something else in there.just looking for some free hp.
I really don´t think you get free HP from an electric waterpump. There may be some other advantages, but you can´t get energy for free!!. The pump motor is powered via the generator now, giving both approx 70% efficiency, so you end up needing TWICE the power if the pump efficiency and the amount of water pumped around are the same. Because the serpentine now has to transfer more power to the generator, I don´t think that the serpentine losses will be less. I have the feeling they will increase as well because twice the power is needed. After all you need to cool the engine.
