Electric Water Pump?
Old Feb 20, 2006 | 04:57 AM
REDC4CORVETTE's Avatar
REDC4CORVETTE
Meziere HD
Don't make the mistake like I did ,I thought Jegs sent me a Meziere HD
and it could not even keep up with the cooling system ,it was just a regular Meziere .It was more like a slurry pump ,it did nothing,to turn over the cooling system.
Old Feb 20, 2006 | 07:08 AM
Nico's Avatar
Nico
From: 1984 crossfire, Alhaurin de la Torre Malaga, Spain
Originally Posted by Nico
I really don´t think you get free HP from an electric waterpump. There may be some other advantages, but you can´t get energy for free!!. The pump motor is powered via the generator now, giving both approx 70% efficiency, so you end up needing TWICE the power if the pump efficiency and the amount of water pumped around are the same. Because the serpentine now has to transfer more power to the generator, I don´t think that the serpentine losses will be less. I have the feeling they will increase as well because twice the power is needed. After all you need to cool the engine.
I was wrong guys, 93RAGTOP did correct me here :o
At high RPM the normal fuelpump needs and deliverd MUCH more than required, the electric does not. I like to buy one as wel!!!
(You really learn a whole lot here at the forum)
Old Feb 20, 2006 | 10:06 AM
stubbs's Avatar
stubbs
Well I researched this some time ago and it fits for me in the same catergory as Underdrive Pulleys, go ahead and use them if you want, not me, I have a 1430 watt stero system, and the underdrive would just make street driving horrible, the Elec water pumps are 10 times as much trouble as the standard type, for the few HP you get, and I'm moving to Phoenix...........you know 120 degrees in the shade in July, once again, no thanks, not for me.
Any part that has a decent chance of causing more trouble than its worth and adds minimal power is never going to be on my car.
Old Feb 20, 2006 | 12:04 PM
sothpaw2's Avatar
sothpaw2
Again, the main advantage of the epump is to eliminate the crappy LT1/4 timing set to water pump drive. The risk is real if you have an LT4 or cammed car and can't use the LT1 chain set /gears.
If you have a stock LT1 I completely agree.
Old Feb 20, 2006 | 03:55 PM
ScaryFast's Avatar
ScaryFast
Most everything has been said, but there are two things I want to mention:
You don't have to pull the timing cover and remove the drive gear. Leaving it in there won't hurt anything, I have heard lots of CF guys say they left it in with no ill effects. Although, if you're going to do anything more than street driving with an occasional drag run you might want to consider the timing chain upgrade suggested by others.
I have heard good reports about the Meziere HD and the CSR. One of the guys above (I think it was either sothpaw or CorvetteKidNC) told me last year that they had used both with no issues.
I personally have the Meziere HD.
One drawback - it makes working down in the area of the harmonic balancer a PITA because it sticks out over the front crossmember. I've been playing with timing and my knuckles are bloody.
Old Feb 20, 2006 | 05:08 PM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
Originally Posted by REDC4CORVETTE
Meziere HD
So we need to get a HD version? Part Number WP 118??
http://www.meziere.com/index.php?pgName=wp118
Old Feb 20, 2006 | 05:20 PM
aboatguy's Avatar
aboatguy
WP118HD
