Hot under the Hood
Old Feb 20, 2006 | 07:20 PM
PMARTINEZ92126's Avatar
PMARTINEZ92126
Default Hot under the Hood
Im sure this question has come up a few times but I couldnt find a post on "under hood temperatures". I have an 86 vette with a 383 stroker in it. I have the Lingenfelter intake and plenum. I also have TPIS coated headers and Dart Pro alum heads. After the car has warmed up I will sometimes open the hood only to find that it is as hot as an oven. If I stick my finger 1 inch from the header pipe I could seriously burn myself!!! My spark plug wire laid against the header for 10 minutes after warming up and it burned the wire to the core (my fault). Also, the hood gets very very very hot. Almost to hot to the touch. Im wondering if this is the reason the paint on the hood started to crack. Is there anything I can do to bring the temp down in the engine bay?
Old Feb 20, 2006 | 09:17 PM
skateparkdave's Avatar
skateparkdave
St. Jude Donor '05-'06
Is it running ok?? Are your operating temps within reason?? You may be running lean which causes excessive heat. I've seen some glowing headers from a lean condition on an F body. Make sure your fuel pressure and delivery is up to snuff.
Old Feb 20, 2006 | 09:30 PM
Strike3's Avatar
Strike3
My 1987 burned last Thursday, after a year and a half of blood swet and tears. I have the same headers as you but I don't think brand is an issue. Several months ago, after I first installed my new engine, on initial start-up the old Mem-cal had the car running so rich that I was throughing flames out the exhaust and melting a nead-by hedge roll. The headers were glowing red within seconds and wiring and plastic components near the headers melted before I could shut the engine off.
After that, I corrected many tuning issues and installed insulation on cables, spark plug wires and starter. I thought all was well.
I went home for lunch Thursday and had some time to kill, so I took the Vette for a short 5 or 6 minute drive. I pulled back into the driveway and went into the house for lunch. About 20 minutes later, I left the house and began to clime into my van and head back to work. I looked up in the direction of my Corvette and was shocked to see flames shooting out above the right front wheel and along the windshield.
Take these "heat" issues serious. No one should have to feel the sick feeling as their car burns, the way I did.
Old Feb 20, 2006 | 09:40 PM
PMARTINEZ92126
My car caught fire last Valentines because positive cable had somehow been scraped. In time it wore through enough to charge the block with power. It fried my stainless steel brakes lines causing them to ignite and it caused a fire under my Brake Master. Thats why I wanted to know what is too hot for a car. And if other people with 383 engines have this same problem.
Old Feb 20, 2006 | 09:43 PM
RICEKILA's Avatar
RICEKILA
From: Beautiful Down Town "SWINDLEHURST" Long Island NY
Install these and make toast at stop lights with the heat that comes out
Old Feb 20, 2006 | 10:03 PM
Red Tornado's Avatar
Red Tornado
who recalibrated your chip? there could be serious fueling (lack of) issues with the tune.
Old Feb 20, 2006 | 10:26 PM
PMARTINEZ92126
The company "Fastchip" did it about three years ago. I would like to have another person check it out to make sure everything is fine.
Old Feb 21, 2006 | 12:42 AM
stubbs's Avatar
stubbs
Where can you buy those?
Old Feb 21, 2006 | 02:26 AM
Slalom4me's Avatar
Slalom4me
PCMforless is well regarded here. CF member Alvin represents them and appears often
in C4 Scan & Tune, as well as in C4 Tech.
Old Feb 21, 2006 | 02:34 AM
Slalom4me's Avatar
Slalom4me
I believe his are from Corvette Central. Greenwood and Mold Kraft
also offer vents.
Here is a thread with those three and perhaps some other sources.
'who sells these hood scoops (GS977: 01-11-2006, 07:32 PM)'
I didn't look to see if it was covered in this thread but there has been
discussion about where the water goes when there is rain. Some of
the vents are reported to have more sophisticated arrangements than
others. Advanced searches on Greenwood and/or Mold Kraft will bring
back the threads.
Old Feb 21, 2006 | 06:59 AM
jerkyboy's Avatar
jerkyboy
Also check your timing. I mistakenly had my timing retarded 8* with my DFI. Sucker was running so hot, I couldn't touch my center console Fixed timing and no more problem!
Old Feb 21, 2006 | 08:00 AM
runner140*'s Avatar
runner140*
Time for a 3" raised cowl hood? Sounds like you need to get the heat out of there.
Old Feb 21, 2006 | 08:51 AM
bacardioil's Avatar
bacardioil
get them from greenwood them self. they make the best ones i have them and they work well. you get what you pay for
regards
Old Feb 21, 2006 | 09:00 AM
c4cruiser's Avatar
c4cruiser
Getting hot underhood air out from under the hood has always been an issue with header-equipped C4's. Engine timing plays a big part as the headers radiate more heat because they are typically larger and longer than the stock GM manifolds in either cast iron or steel tube.
If you think of the motor as a giant heat sink, there is a lot of heat stored under the hood. Coolant temps also play a part in heat build-up. Having the coolant at 180 instead of 295 to 210 helps keep underhood temps down.
A number of years ago, Corvette Fever ran an article about a company that developed a set of exhaust fans that installed in the fender wells to help extract hot air. They looked like PC fans and were small enough to fit up to 3 per side depending on how much of a heat problem there was. You could wire them to a temp sensor for automatic operation or just a toggle switch.
Don't know what happened to the company but it seemed like a great idea.
Old Feb 21, 2006 | 10:52 AM
Slalom4me's Avatar
Slalom4me
An 80mm PC case fan (3.14" fan) is typically capable of 30-35 CFM flow.
These are not typically designed for use in harsh, external conditions.
Derale Tornado fans flow between 400 CFM for the 7 & 8" (4.8A) up to
2175 CFM for the 16" (18.4A). Spal fans are well known for their flow
characteristics, too.
I've haven't seen it done on a C4 but I believe it is Superformance's
version of the Cobra Daytona Coupe that uses Derale-like fans to
pull air out of the engine compartment.
Old Feb 21, 2006 | 11:23 AM
stubbs's Avatar
stubbs
I read that article too C4cruiser, now I have to dig through boxes and boxes of old magazines to try and find it.
Old Feb 21, 2006 | 06:04 PM
PMARTINEZ92126
any thoughts on wrapping the headers in that header wrap i see at the hot rod shop? Its like a cloth in a roll that comes in about 10 to 15 foot rolls. I just ordered some of those boot guards for each plug wire. I see them advertised for 40 -60 bucks for a set of 8 but I found them for 27 dollars online. Hopefully I wont burn any more wires. I do believe its time to get the Headers recoated because the ceramic coating is flaking off. Should I go with the same coating or try something else?
To Hot under the Hood
Old Feb 21, 2006 | 06:21 PM
Slalom4me's Avatar
Slalom4me
Header wrap is what you use after you make sure everything else is
as it should be. There are pros and cons but let's hold off on those
for now.
Start by looking into the basics of a tune-up (parts in good condition
and all settings within parameters) which you can pretty much do
yourself. Then see someone local or gather the knowledge and
equipment necessary to work with a remote tuner.
Use the Advanced Search to find several recent threads about
'Headers' or 'Exhaust glowing red hot' to read about others who have
experienced what 'skateparkdave' posted about above and how they
solved this problem.
Old Feb 21, 2006 | 06:41 PM
RICEKILA's Avatar
RICEKILA
"Corvette Central" & "King Kullen"
Old Feb 21, 2006 | 07:07 PM
Eike's Avatar
Eike
I think Swain Tech is a good option. They coated my Hookers and I'll post the result as soon I have them on the car.
