335's on the back?
I have a 96 GS with a DRM coilover and it is lowered. I want to have as much rubber down as possible for autocross.
Can I run 335/35's on the back? What offsett and size (width) of wheels should I get to accomplish this? I'm thinking 17's with 50mm ofset but now I'm not sure. Also, if you would suggest wheel brands that would be helpful also.
ZR1's BARELY have clearance for 335's with the correct offset, and they are 1.5" wider on each side.
I can fit 12" Goodyears on mine, but they rub a bit on the inside. I have 1/4" spacers and use CCW's. I have no clearance between the fender lip and the tire...sometimes they rub under load on the inner fender lip.
Brian Cunningham's car has 335's on 12" wheels at all four corners.
Street driven to boot.
He has posted many times about this set up, here is one thread with
his remarks.
had your exact set up. You are trying to go pretty big and while CCWs
might get you there, they come at a cost. I don't have an answer
but I can give you some more to think about if you like.
My car is an '89 with the FE1 suspension at the stock ride height
(highish). No matter what suspension your '96 has, it is softer than
mine at the front and only the '96 F45 has the same rear rate. This
plus I gather your car is lowered changes the picture as far as
interference under load. Here're the numbers
1989
FE1 93.1 39.9 (CPE)
1996
FE1 60.0 26.0 (CPE)
Z51 73.2 33.0
F45 73.2 39.9
I have OEM 18x11 Z/06 wheels w/ 305/40 Hoosiers. I don't have much
time on these and none under aggressive conditions. I can say that
my Earl's SS lines clear, that there hasn't been any rubbing at the
front at lock (you'll remember that Vetracr spoke about trouble with
17x11 GS wheels and the swaybar) and that they are just inside of an
imaginary line dropping from the fender lip.
These wheels have 50mm offset. I am going out to measure the
backspacing from the outer lip to the wheel mounting flange after I
post this.
Tell us more about the dimensions of the wheels you found in Jan
rears are 8.5 inch backspacing (17x11).
them yourself?
I am wondering because an 11" wheel with 50mm offset would work
out to about 7-1/2" from the inside of the lip to the face of
the flange. If you measured from the outside of the lip, I don't think
this would add an inch, maybe just 1/2". So I think your wheels have
more than 50mm offset.
http://www.tirerack.com/tires/Compar...=8&RunFlat=All
it has original 17x 11 ZR1 wheels from a 90,s ZR1
i bought fenderflares and installed them:
pirelli p zero assymetrico tires
no spacers !
work great !!
greetzz jeff stingray
no spacers !
work great !!
do u have a pic from directly behind the rear? and from the side?
thanks!
I guess my problem is that I want to put as much rubber in the back as possible because I have the power (it has a DRM 480 conversion on the motor and 4:10 gears) to get out of the corners fast, but it is still my street car so I don't want to damage the fenderwells or cut them up with the tires.
Thanks everyone for the replies. Sorry to be so confused.....
Are those the 38 offset or the 50 offset? I may be wrong but I thought that ZR-1 was 38 which should move the tire to the outside more. Does the tire ever rub under hard cornering or over bumps? This definately looks do-able from those pictures.
Thanks for the pictures.
CCW classics Rear: 18x12 w/335x30x18 Front:18x10 w/275x??x18
