I have a 93 auto that came with a d36 with 2.59's. I have installed a d44 with 4.10's and my speedo is way off. At first I was going to go the gear route but I scored a Dakota Digital SGI-5 A for free so i'll try that first. (CFI-EFI - I know they're a waste but free is free )
My one and only question is, which wire (color wise) off of the vss do I use and where is the best place to tap it?
If anyone has installed one of these in the past and has any info or tips, please let me know.
Should have done the gear change for the VSS when youput the d44 in.. Costs only like $10..
I know I should have and will if this thing doesn't work right. The thing was that I had the free box for a while and I was told the VSS I needed was discontinued.
What's involved in changing the gears and the vss anyway?
On my 88, I installed my dakota digital sgi-5 under the upper dash panel, and velcro'd the box on top of the internal a/c ducts.
I tapped into the vss input to the instrument cluster, also found convenient power and grounds to use there. I don't think I'd want to put it under the car near the trans. Inside the rocker panel would be a possibility also.
If I need to adjust, I just have to pop off the dash panel and re-set the dip switches.
The tech support said to use Application #2 but they could not tell me which wire would to use. It counds like i should use the yellow wire so i'll give it a try.
