91 Tach Question
Old Feb 21, 2006 | 08:07 PM
MAZ73's Avatar
MAZ73
Default 91 Tach Question
The tach on my 91 reads a lot higher in RPM's than the motor is actually reving. What could be causing this? All other gauges work fine. Saw a tach filter in corvette central as the only repair option for them. Any help would be apprecieated.
Old Feb 21, 2006 | 09:02 PM
Hairmetal_still_rox!'s Avatar
My 90 has the same problem, I dont believe the filter cures the problem from what I have been told. I am putting an aftermarket tach in.
Old Feb 21, 2006 | 09:28 PM
Polo6speed's Avatar
Polo6speed
I changed tach filter on my 90 and it made no difference. I also cleaned the contacts on the main connector at the firewall. My next attempt will be sending cluster out for rebuild.
In the meantime I installed a Gtech pro in front of the analog tach. Digital tach, shift lights and extras. Works great.
Old Feb 22, 2006 | 02:24 PM
MAZ73's Avatar
MAZ73
Recommend any company in particular to do a rebuild? cost?
Old Feb 24, 2006 | 06:50 AM
MAZ73's Avatar
MAZ73
Ttt
To 91 Tach Question
