Headlights
Old Feb 22, 2006 | 04:52 PM
PsychoNumber1's Avatar
PsychoNumber1
From: Behind The Redwood Curtain, The State of Jefferson
Default Headlights
Repost from General, hoiping to get more help here. TIA
Originally Posted by Me
Headlights
I skimmed through the tech tips already, but I'll ask you anyway
I posted a few days ago about my recent problems. Number one right now are the headlights. Neither of them come up, at least not on a regular basis (the passenger side started working again and then quit). The tech tip on the bushings said that the motor would continue to run, mine doed not. The headlights both start to move (maybe a half inch) and then stop, along with the motors. The driver's said has done this before, quite a while back, but it started working again and hasn't been an issue again until now. It has been fairly cold this winter, but nowhere near as cold as many of you experience (occasionally down in the 30's over night). Are there any adjustments or lube points or anything like that? Could it still be the bushings or maybe the motors themselves?
Next task: Seat belts... (the driver's side doesn't come out without manually moving the release) But that's a whole nother topic for a later date.
how about pointing me in the right direction in the helms manual, I've been looking through it and found headlights in the electrical sections, but they work fine, it's the motors I need to find.
Old Feb 22, 2006 | 07:03 PM
CorvAdel's Avatar
CorvAdel
I'll jump in here and give an opinion baased on my experience....it is the gears in both of your h/light motors.
They are readiliy avail. and not expensive, but a bit of APIA to fit, as you need to disassemble much of the assembly...
If you need to drive the car until you get the parts and fix it permanently, you can manually wind the motors up, then disconnect the grey elec. plugs. This way the lights are up and you can turn the lamps on and off without the motors moving...Hope this helps..
Old Feb 22, 2006 | 07:14 PM
guyjay777's Avatar
guyjay777
Default clicking headlights
92 blk LT1 auto 71k...my headlights click after they go down..is it the motor too...did yours click before they stopped working?
Old Feb 22, 2006 | 08:22 PM
PsychoNumber1
thanks for the response. Do you just use the **** that spins on top of the motor? I don't NEED to drive it right now, but we have a dinner run with our club that I'd like to take the vette to. I'll try winding them up this weekend.
btw- I found what I was looking for in the supplemental service manual.
Old Feb 22, 2006 | 08:25 PM
CorvAdel's Avatar
CorvAdel
...sorry...you need to disconnect those grey elec. plugs BEFORE winding the motors up using the ***** on "top" of the motors....otherwise you may find that they will try and turn back on you...very suddenly!!
Old Feb 22, 2006 | 08:43 PM
Insane1's Avatar
Insane1
It's probably the bushings in your motor/gears. I was in Autozone today and in the Help! section the had some pins for window regulators that looked just like the bushings I put into my motors last night. They were $7.99 and they came 3 to a pack, just like what the headlights use.
Old Feb 23, 2006 | 11:04 AM
PsychoNumber1
I saw the bushings on ebay for $1.99 for 6 the other day. I'll report back when I have some results for you guys. Thanks!
Old Feb 23, 2006 | 11:10 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
It's your bushings. The characteristic THUNKA THUNKA THUNKA THUNK!!!! noise four to six seconds after your lamps close is a dead giveaway.
Get the bushings from Eckler's, MAM, or Corvette Central or at Home Depot by asking them for item number 595609. They run about .69 cents for a pack of three. You'll need 6 to repair both lights.
Click the link below for install help. You can also search the C4 TechTips archives here for several excellent articles.
http://corvettefever.com/howto/33098/
Old Feb 23, 2006 | 11:11 AM
onedef92's Avatar
onedef92
Click this link for install help http://corvettefever.com/howto/33098/
Old Feb 23, 2006 | 11:26 AM
PsychoNumber1
Awesome!
Old Feb 23, 2006 | 12:12 PM
onedef92's Avatar
onedef92
Awesome!
Ask and ye shall receive....
Old Feb 23, 2006 | 08:57 PM
VetNutJim's Avatar
VetNutJim
Cruise-In I Veteran
That's egzsactly what mine sounds like. But they still work...
Guess they will quit with a ker-chinka ker-chinka ker-chinka sound?
Old Feb 24, 2006 | 09:09 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
I thought that 84-87 have the gear problem and NO bushings
Heres some info on the doors. By the sound of it, you may have already found it but others looking may benifit.
http://members.shaw.ca/dankai/Headlight%20Doors.pdf
Old Feb 24, 2006 | 09:15 AM
onedef92's Avatar
onedef92
Not for long, Jim. That's the C4 headlight death throes. They're gonna' slip and fail soon. Get ready for a bushings overhaul.
Old Feb 27, 2006 | 12:49 PM
PsychoNumber1
yeah, it seems that they have gears that fail. But when I was looking at MAM, they said early 87's, how can I tell if that's what I have?
Old Feb 27, 2006 | 02:41 PM
onedef92's Avatar
onedef92
All 1984-87 cars had the GEARS, no bushings. The 1988-96 Vettes had the bushings/gear combo.
Old Feb 27, 2006 | 03:57 PM
PsychoNumber1
Old Feb 27, 2006 | 05:18 PM
CorvAdel's Avatar
CorvAdel
..and 84-87 had 3 elec. wires going to the grey connector, whereas 88-96 had only 2.
To Headlights
