High Idle...WTF?
Old Feb 22, 2006 | 07:55 PM
JEFNLSA's Avatar
JEFNLSA
Default High Idle...WTF?
Ok, I'm driving home from work today and as I get into a little stop n' go I realize that my idle is stuck at 1500 rpms - hence the WTF? I tap the pedal...no change...continue cruising...no change. Stopped by a shop (mechanic there who's done some work for me before) once I hit my side of town, pop the hood and we both look at it. Nothing out of the ordinary, everything looks AOK. No SES, temp looks good, throttle cable stopping where it should etc...
WTF? I'm baffled as was he. So I drove it home and in the garage it sits...any ideas?
Old Feb 22, 2006 | 08:07 PM
redvette6spd's Avatar
redvette6spd
I to have on occasion had the same trouble if I turn the car off for a few minutes it goes back to normal
Old Feb 22, 2006 | 08:54 PM
Lichen's Avatar
Lichen
Been pumping steroids into the gas-tank again? Maybe TPS? Did you manually close the throttle all the way down?
Old Feb 22, 2006 | 09:02 PM
cv67's Avatar
cv67
St. Jude Donor '05
Wonder if your TB blades are hanging open.
Old Feb 22, 2006 | 09:04 PM
JEFNLSA's Avatar
JEFNLSA
Manually...yes.
When the throttle is "all the way down" it still idles @ 1500 or a tad less, which is far from the normal idle rpm.
Old Feb 22, 2006 | 09:07 PM
JEFNLSA's Avatar
JEFNLSA
Actually my battle plan is to go by the ZFdoc's tomorrow after work and take a look at the TB and see if something's up - as he thought the same thing.
Old Feb 22, 2006 | 09:15 PM
Lichen's Avatar
Lichen
If it's a BBK, then it probably is hanging up. Trevor had to sand mine down to make it work properly (took about 5 minutes).
Old Feb 22, 2006 | 09:17 PM
froggy47's Avatar
froggy47
Vacuum leak.
Old Feb 23, 2006 | 01:33 AM
Shawn_65's Avatar
Shawn_65
wouldnt this be the Idling air control(IAC) motor? not sure where to access it, but you can adjust the idle. Perhaps it got loose or hit i dunno. gl
Old Feb 23, 2006 | 04:55 AM
REDC4CORVETTE's Avatar
REDC4CORVETTE
When was the last time you cleaned the TB?
Old Feb 23, 2006 | 06:36 AM
mseven's Avatar
mseven
TB a good place to begin, even a big vac leak can have that effect, brake boost etc.
Old Feb 23, 2006 | 09:58 AM
JEFNLSA's Avatar
JEFNLSA
Update:
I start her up this morning and she's fine. It's gotta be the TB hangin' up. After work I'm going by the ZFDoc's & do a little surgery and clean her up at the same time. Should correct the problem.
Thx for the help everyone...I'll post results of fix.
Jeff
Old Feb 23, 2006 | 11:38 AM
TM-Z06's Avatar
TM-Z06
Mine does that on occasion...usually when its cold out. It'll idle at 1000-1200 rpms....After car warms up, the idle settles down to 700rpm.
Old Feb 23, 2006 | 01:26 PM
JCOrion's Avatar
JCOrion
My solution was to lube the throttle plate, it would get stuck sometimes.....its the dredded BBk 52mm disease....
On a good note though, its been fine ever since...I will probabaly just lube it every 6 months just in case...
To High Idle...WTF?
